Encoder PPR cutting thread
23 Jun 2017 08:17 #94823
by timmert
Encoder PPR cutting thread was created by timmert
Hi
Im retrofitting my lathe to LinuxCNC. The spindle has an encoder with 2 outputs. These outputs are 1ppr (pulse per revolution) and 360ppr. I know LinuxCNC needs 2 encoder signals (1 index). Will the 360ppr be enough for cutting thread? The 1ppr could be the index pulse.
Cheers
Cheers
23 Jun 2017 15:20 #94851
Replied by PCW on topic Encoder PPR cutting thread
360 PPR is fine for cutting threads
(its even possible with 1 PPR but that has issues if the spindle speed is not well regulated)
If you have 3 signals (A,B,Index) you can do rigid tapping
23 Jun 2017 17:24 #94858
by timmert
Replied by timmert on topic Encoder PPR cutting thread
thanks for the reply PCW!
Time to create page: 0.508 seconds
