Emco 240 Tool Turret
06 Sep 2017 17:28 #98591
by timmert
Replied by timmert on topic Emco 240 Tool Turret
I understand your reply andy.
But for a complete electronic noob like me its not possible to find out all those things with the original control.
I just found the boxford component. Its also a 8 tool turret with the same design as the emco. Would it work?
When i have tool 1 loades and i switch to tool 3. linuxcnc should know how much degrees it needs to turn.
07 Sep 2017 09:01 #98614
by timmert
I used HALcompile to install the toolchanger.comp
I currently struggle with the hal file.
This is the example inside the documents. But it uses an old format I think (some files are called EMC).
What are the equivalents in the current format?
The first entries are clear to me. But I'm not sure about:
net apos-cmd axis.3.motor-pos-cmd and the entries underneath.
I already added the A axis.
# example Hal linkages required:-
setp stepgen.3.position-scale [AXIS_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 16000
setp stepgen.3.dirsetup 31000
## make sure accel and velocity are sensibly low or it will take off!
setp stepgen.3.maxaccel [AXIS_3]STEPGEN_MAXACCEL
### must unlink these 2 to access stepgen.3.position-cmd
### and prevent continual following errors if motor-pos-fb left linked
#net apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd
#net apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
net aenable axis.3.amp-enable-out => stepgen.3.enable
08 Sep 2017 09:12 #98655
by Grotius
Replied by Grotius on topic Emco 240 Tool Turret
Hi Timmert,
So finally you are using a stepper.
To program your turret with G-code switch your program style with :
G90 Absolute programming
G91 Incremental programming
If you put this in a macro then you can load (exexute) the macro if you want to change tool.
What you say before is good. You take a few degrees more to ensure it's
in the slot backward's.
08 Sep 2017 09:38 #98656
by timmert
If I understand you correctly
I nee to manually execute the macro to switch to the desired tool.
That's not what I want. Because I need to calculate for each program how many positions it needs to change.
It should work like this.
Tool 1 is loaded. LinuxCNC knows this.
When I issue a M6 T3 (or T0303) it should know it needs to move 2 positions.
08 Sep 2017 12:06 #98670
Replied by andypugh on topic Emco 240 Tool Turret
Not related to the questions you are asking, but you don't want your A-axis in the GEOMETRY.
(I am not even sure you want it in the COORDINATES, if you are using a HAL component)
09 Sep 2017 07:57 #98722
by timmert
Ok
Whould it be possible to remap the toolchange code (m6 t2 / t0202) for example to a macro?
09 Sep 2017 23:54 #98752
Yes, it's quite easy.
What language do you want to write the macro in?
10 Sep 2017 16:42 #98782
by timmert
I received this code on a local forum.
It's being used for a 6 position emco toolchanger. But can be changed to 8 position I think.
sub change_tool
;Switch off guard for tool change area collision
TCAGuard off
;Use #5015 to indicate succesfull toolchange
#5015 = 0 ; Tool change not performed
; check tool in spindle and exit sub
msg"Current 5008 "#5008
msg"new 5011 "#5011
IF [ [#5011] <> [#5008] ]
IF [[#5011] > 6 ]
ERRMSG "PLEASE SELECT A TOOL FROM 1 TO 6."
ENDIF
ENDIF
IF [#5011]>[#5008]
#4600=[#5011-#5008]
ENDIF
IF [#5011<#5008]
#4600=[[#5011-#5008]+6]
ENDIF
#4601=[[#4600*60]+3]
msg #4601
G00 G91 A#4601
G00 G91 A-4
G90
M6T#5011
G43
;Switch on guard for tool change area collision
TCAGuard on
;;Check if ZHeight comp was on before and switch ON again if it was.
;if [#5019 == 1]
; ZHC on
;endif
EndSub
10 Sep 2017 17:11 #98785
That isn't in LinuxCNC G-code. Mach3 perhaps?
10 Sep 2017 17:45 #98786
by timmert
It's USBCNC I think
