Spindle encoder wiring check
- Thank you received: 1369
22 Sep 2017 12:34 #99254
Replied by Todd Zuercher on topic Spindle encoder wiring check
They always have an A and B pulse. They may or may not have an index pulse. But the encoder will have to be connected to the spindle in a 1:1 ratio in order to make use of the index pulse on the encoder. If your current setup has a separate index pulse you can continue to use it with the new encoder.
22 Sep 2017 14:26 - 22 Sep 2017 14:30 #99263
by timmert
Replied by timmert on topic Spindle encoder wiring check
Thanks Todd!
I need to find an encoder with index pulse, because it saves some work adding a second encoder for only the index pulse
It's 1:1 belt connection
'Edit
robokitsworld.com/sensors/encoders/rotar...-10000cpr-with-index
This would work I think
'Edit
Last edit: 22 Sep 2017 14:30 by timmert.
22 Sep 2017 14:32 #99264
by tecno
Replied by tecno on topic Spindle encoder wiring check
Power Supply: 8-30V
You need 5VDC
You need 5VDC
22 Sep 2017 14:36 #99265
by timmert
Stupid question but not possible to use an external power supply instead of the power on the mesa board? ( i have 12v and 24v in my controls).
22 Sep 2017 14:38 #99266
by tecno
Mesa encoder input is 5V so you need 5V encoder not 8-30V.
You supply 5V from Mesa board to encoder
22 Sep 2017 14:39 #99267
by timmert
ah ok, the search continues haha
22 Sep 2017 17:15 #99282
by Clive S
Replied by Clive S on topic Spindle encoder wiring check
Just a thought but the encoder might be putting 5V out even if the input is 8-30v.
03 Oct 2017 12:47 #99809
Replied by andypugh on topic Spindle encoder wiring check
It might, or perhaps open-collector or similar. But the data sheet simply does not say.
There are some 24V NPN output encoders on eBay, those might work, if the encoder inputs have pull-ups.
eBay also has lots of very cheap 5V AB-only encoders for about £7. At that price using a keyway on the spindle for the Z-phase looks tempting.
10 Nov 2017 10:50 #101591
by timmert
Not sure if I understand it correctly. But would I need an encoder to my z axis?
10 Nov 2017 11:02 #101593
I am saying that you can add extra hardware to supply an index pulse entirely separately from the existing encoder.
Time to create page: 0.083 seconds
