PWM generator does not start until the second run
- TwoFeetDown
- Topic Author
- Thank you received: 8
19 Jul 2017 00:20 #96029
by TwoFeetDown
PWM generator does not start until the second run was created by TwoFeetDown
After considerable fooling around I finally have PWM controlling my laser using pwmgen. It only Issue I now have is that the PWM generator does not seem to start the first time I run AXIS (2.7.0). The second attempt is normally successful.
Any ideas as to how I can get it to kick in on the first attempt or will I just have to start it, stop it, and restart it each time?
Thanks for any insight you can offer. -Jim
19 Jul 2017 00:46 #96030
Replied by PCW on topic PWM generator does not start until the second run
Pretty hard to guess whats going on without more information
Can you post your hal/ini files?
Is it possible the laser has some problem with the startup PWM state?
- TwoFeetDown
- Topic Author
19 Jul 2017 19:47 #96098
by TwoFeetDown
Replied by TwoFeetDown on topic PWM generator does not start until the second run
I should have thought of that. Here are all the related files in the /config folder.
As I mentioned, the laser modulates just fine on the second run but not on the first run.
Thanks again,
Jim
Thanks again,
Jim
Time to create page: 0.131 seconds
