Linuxcnc and stepper motor comunication
24 Jul 2017 14:12 - 24 Jul 2017 14:16 #96348
by b33felix
Linuxcnc and stepper motor comunication was created by b33felix
Hi all, first of all, excuse my poor english.
right to it: i cant manage to make my stepper motor move at all, the 7i76 output energizes/de-energizes the motors just fine apparently (first time seeing a stepper in action) when the motor energizes it makes a *stiffening* noise; probably just normal; and it holds the torque just fine.
checked pins on the 5i25/7i76 with halcmd show pin, and the enable signals work, so i would think the boards are just fine.
the driver has a green led light to show power indication. when i power up the driver this led lights up. it also has a red light, for when current exceeds rated value or voltage lower rated value, the red LED lights.
interenting enough, i can see throgh the driver metal enclosure, a red light from the inside of the driver. a different one than the one specified above. It's on all the time. i dont know what it means thou.
i would be inclined to say that the wiring between the driver and the motor is wrong, but as i have been told, i would still see some kind of step movement, wiggling or something from the motor. instead of just holding torque. btw, the motor makes no sound when holding torque or when sending movement commands to the joint.
if its of help, ill link the manual of the motor and the driver for better reference.
Driver (this one has a slight variation to mine, but its quite similar) : purelogic.ru/files/downloads/doc/Driver/...ko_Purelogic_eng.pdf
motor (find in page: FL86STH80-4208B) to found this specific motor datasheet : lineartec.com.ar/catalogos/19Fulling.pdf
please tell me if im missing any important information about the problem. thank you
Frank
Frank
Last edit: 24 Jul 2017 14:16 by b33felix.
- Thank you received: 1369
24 Jul 2017 15:49 #96353
Replied by Todd Zuercher on topic Linuxcnc and stepper motor comunication
Are you sure you have the wiring between motors, drives, and 7i76 correct?
What have you set the drive timings to?
Specifically these settings for each joint/axis in your ini file:
DIRSETUP =
DIRHOLD =
STEPLEN =
STEPSPACE =
24 Jul 2017 16:04 #96354
by b33felix
Replied by b33felix on topic Linuxcnc and stepper motor comunication
reply+update:
i could make the motors move, changing the wiring on the driver output, but it may still be wired wrongly on the motor side. as it moves but about 1/8 of the distance it should and in a very stiff manner, i think the schematics on the manuals are wrong, i need to figure which cable is in each phase, anyone knows where to find the info?
i would think the 7i76/driver are doing their job according to what happened. correct me if im wrong, i dont have experience on the subject
todd, i've changed those settings to be:
DIRSETUP = 1000
DIRHOLD = 2500
STEPLEN = 1000
STEPSPACE = 2500
thank you for the quick reply on the topic. appreciate it
Frank
DIRSETUP = 1000
DIRHOLD = 2500
STEPLEN = 1000
STEPSPACE = 2500
Frank
24 Jul 2017 17:14 #96359
Replied by PCW on topic Linuxcnc and stepper motor comunication
I would double the steplen number and try again
The following user(s) said Thank You: b33felix
24 Jul 2017 18:34 #96362
by b33felix
oh boy, you sir, you have special powers. as usual, pcw is here to save the day! haha, its working. beautifully. just one question, how can i tune those 4 numbers to take out the best out of my stepper?
26 Jul 2017 16:45 #96492
Those numbers will either make the motors work properly or not. There isn't really any tuning to be done once things are working.
Replied by andypugh on topic Linuxcnc and stepper motor comunication
- photomankc
- Thank you received: 4
26 Jul 2017 19:15 #96499
by photomankc
Replied by photomankc on topic Linuxcnc and stepper motor comunication
2nd-ing Andy here. There is nothing to tune or adjust there. STEPLEN is the minumum number of nano-seconds the step pulse should last. The driver dictates this, as it can either reliably detect every step pulse or not, there is not any in-between area to exist in and tune for. 2000 means 2 microseconds and combined with 2500 yields 4.5 microseconds minimum between pulses. That gives a maximum pulse rate of 222KHz. Most handle 200 to 250KHz so that's in the ball park. Most drivers I have played with tend to look like this:
STEPLEN 2500
STEPSPACE 2500
5 microseconds for a complete pulse, and a pulse rate of 200KHz. That's usually a fairly safe bet on most drives but generally the drive manufacturer must tell you the exact settings to specify.
Let's say you have 5 turn per inch ball screws and 200 step per rev motors. That's 1000 steps per inch. You setup 8X microstepping on the driver so 8000 pulses per inch now. If you want to move at 4 inches per second (that's pretty fast) you still only need 32KHz to do it. You can see, there is little need to try and push right to the lowest limit on the timing. So you can generally pad the numbers with 500 to 1000 extra without any harm.
STEPLEN 2500
STEPSPACE 2500
26 Jul 2017 19:48 #96506
by b33felix
thanks guys, you really made it clear to me. now i have a much better understanding of a stepper motor. im finishing my first build right now, and im already thinking of building another machine, is it just me or it kind of gets an addiction this stuff, good thing at least i can make money with them hehe.
26 Jul 2017 21:54 - 26 Jul 2017 21:54 #96516
No, it's not just you.
Hello, my name is Andy and I am a retrofitoholic....
You also get more ambitious. I spent more on custom-made castings for my Holbrook lathe conversion than I spent on my entire first conversion. (and that includes buying a brand-new Chinese lathe.mill machine)
Last edit: 26 Jul 2017 21:54 by andypugh.
27 Jul 2017 04:53 #96534
Andy, I'm sure I remember you saying on one thread that castings were reasonably priced in your neck of the world. I think the truth is coming out....
But your work on that machine was amazing!
Replied by rodw on topic Linuxcnc and stepper motor comunication
Time to create page: 0.153 seconds
