Wireless XHC-HB04 pendant 'always connected'
01 Aug 2017 19:27 #96856
by hwylie
Wireless XHC-HB04 pendant 'always connected' was created by hwylie
Evidently, no error is reported by 'libusb_control_transfer' (called from 'xhc-hb04.cc') when the wireless pendant (model WHB04-L) is switched off.
This means 'require_pendant' in INI stanza [XHC_HB04_CONFIG] has no effect: HAL pin xhc-hb04.connected is always asserted.
Is this a limitation of the XHC (wireless) pendant / USB dongle design, or is there a workaround to correctly acquire pendant status?
LCNC version is current Master (Debian OS).
01 Aug 2017 19:41 - 01 Aug 2017 19:51 #96857
by dgarrett
Replied by dgarrett on topic Wireless XHC-HB04 pendant 'always connected'
Connection loss occurs when you remove the usb connection.
excerpt: configs/sim/axis/xhc-hb04/README
github.com/LinuxCNC/linuxcnc/blob/master...axis/xhc-hb04/README
From the man page
linuxcnc.org/docs/devel/html/man/man1/xhc-hb04.1.html
Ref:When require_pendant = no, the xhc-hb04 hal pins will be created even if the pendant is not connected at startup. A new connection, a disconnect, and a reconnect are supported.
From the man page
Ref:(bit out) xhc-hb04.connected True when connection to the pendant is established over the USB interface.
Last edit: 01 Aug 2017 19:51 by dgarrett.
02 Aug 2017 06:57 #96881
by hwylie
Replied by hwylie on topic Wireless XHC-HB04 pendant 'always connected'
Thank you - 'libusb' scope being only the USB interface, it is understood that HID status is an application layer issue - and as for wireless USB devices in general, the driver is unaware of absence of device power, wireless link error rate, etc.
Time to create page: 0.056 seconds
