Connect relays to 7i76
05 Aug 2017 13:24 #97029
by timmert
Replied by timmert on topic Connect relays to 7i76
I connected a 24v power supply to the vfield of the 7i76.
Home switches are working.
But I don't measure a 24V on the output of TB5-output pin 8
Hal file:
# --- COOLANT-FLOOD ---
net coolant-flood hm2_5i25.0.7i76.0.0.output-08
Am I missing something?
Hal file:
05 Aug 2017 13:35 #97030
Replied by PCW on topic Connect relays to 7i76
Do you have the correct output pin? (output 8 is TB5 pin 17)
Have you looked at hm2_5i25.0.7i76.0.0.output-08 with halmeter?
05 Aug 2017 13:40 #97031
by timmert
Pin 17, TB5 = output 8
HALmeter switches from false to true when I click the Flood cooling
05 Aug 2017 13:49 #97032
How are you probing the output? note that the terminal block screw
may not be connected to the output pin if not tightened
05 Aug 2017 13:59 #97033
by timmert
Multimeter set to voltage, red wire to the output, black wire to ground
Then I press the coolant switch.
When connected the relay I don't hear it 'clicking'
05 Aug 2017 14:05 - 05 Aug 2017 14:05 #97034
Is it possible you have the flyback diode backwards?
Is the meter/relay ground on the field ground pin?
(field I/O is isolated so if you have a floating 24V supply, field ground will not be connected to logic ground)
Last edit: 05 Aug 2017 14:05 by PCW.
05 Aug 2017 14:12 #97035
by timmert
I did the following:
A Meanwell 24V power supply
Connected to Vfield of 7i76
Pin 5 and 8
5 = vin logic 8-32V
8 = gnd
From the relay A1 I have a wire to the output 8 (on tb5)
A2 from the relay goes to the central ground point.
I don't have a flyback diode yet.
Pin 5 and 8
5 = vin logic 8-32V
8 = gnd
05 Aug 2017 14:19 #97036
Normally you would connect +24V to TB1 pin 1 24V common to TB1 pin 8
and have jumper W1 in the left hand position
Also the relay A2 (and meter black lead) must connect to TB1 pin 8
05 Aug 2017 14:22 #97037
by timmert
Ok
Will try and check tomorrow
What can happen when I dont connect the flyback diode?
05 Aug 2017 14:28 #97038
Outputs can be damaged if there is no flyback diode and the relay current is > 60 Ma or so
Normally small 24V relays are fine without a flyback diode since they only draw 20 to 40 mA
The output drivers are designed to drive inductive loads and have flyback protection
but it is not as robust as a flyback diode
Time to create page: 0.148 seconds
