linuxcnc runs fine in sim but won't run my-mill
12 Aug 2017 15:38 #97385
by skrap58
linuxcnc runs fine in sim but won't run my-mill was created by skrap58
I have installed linuxcnc on a clean install of linux mint 18.2 using post 3 and 4.1.0-1 rtai kernel. I can start and run axis in sim mode but when I try to run my-mill I get the following errors on start up
@cnc ~/linuxcnc-dev/src $ linuxcnc
LINUXCNC - 2.7.10
Machine configuration directory is '/home/wwp/linuxcnc/configs/my-mill'
Machine configuration file is 'my-mill.ini'
Starting LinuxCNC...
Found file(REL): ./my-mill.hal
Note: Using POSIX non-realtime
config string '0 out'
Found file(REL): ./custom.hal
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
USRMOT: ERROR: command timeout
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
/usr/bin/linuxcnc: line 496: 28463 Killed $EMCTASK -ini "$INIFILE"
Waited 3 seconds for master. giving up.
stepgen: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
hal_parport: not loaded
motmod: not loaded
trivkins: not loaded
<commandline>:0: unloadrt failed
LinuxCNC terminated with an error. You can find more information in the log:
/home/wwp/linuxcnc_debug.txt
and
/home/wwp/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
wwp@cnc ~/linuxcnc-dev/src $
Im think it is a config problem but I do not know where to look.
Thank you in advance for the help.
Bill
LINUXCNC - 2.7.10
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
stepgen: not loaded
motmod: not loaded
and
Bill
12 Aug 2017 15:59 #97386
Replied by PCW on topic linuxcnc runs fine in sim but won't run my-mill
Quote:
Looks like you are not running a real time kernel
what does:
print?
what does:
uname -a
print?
12 Aug 2017 16:59 #97389
by skrap58
Replied by skrap58 on topic linuxcnc runs fine in sim but won't run my-mill
wp@cnc ~ $ uname -a
Linux cnc 4.1.0-1-rtai-686-pae #1 SMP PREEMPT Debian 4.1.18-2linuxcnc (2016-08-16) i686 i686 i686 GNU/Linux
Thank you for the rapid reply.
12 Aug 2017 19:45 #97397
Not that familiar with RTAI but i might guess that the version of LinuxCNC you have does not work with the
RTAI kernel you have
15 Aug 2017 16:58 #97522
I wonder if this is what you get with the "uspace" version of LinuxCNC if you have the RTAI kernel?
Does Synaptic show it as two different versions?
Replied by andypugh on topic linuxcnc runs fine in sim but won't run my-mill
15 Aug 2017 18:41 #97530
by skrap58
Thanks Guys for the replies. You are correct the rtai kernel is not a real time kernel. I ended up going with Linux Mint 18.2 and there is a realtime kernel in the Synaptic Package manager that worked out of the box. So I am up and running. Now I am trying to get nativecam installed and embedded.
Thanks again for the help.
Bill
Bill
Time to create page: 0.075 seconds
