Spindle as speed counter clockwise.
14 Aug 2017 13:07 #97449
by timmert
Spindle as speed counter clockwise. was created by timmert
Hi
I have configured spindle at speed, working great (clockwise rotation)!
The lathe sometimes needs to run counter clockwise. The gui shows for example: -2.500RPM.
The problem is that the gcode doesn't continue and the spindle as speed led stays off.
How to solve this?
How to solve this?
15 Aug 2017 08:56 - 15 Aug 2017 08:57 #97496
by timmert
Replied by timmert on topic Spindle as speed counter clockwise.
I think the problem is that counter clockwise shows a negative value?
How can I configure it to show a positive value?
This is what I can find in my HAL file about the direction of the motor
net spindle-ccw => hm2_5i25.0.7i76.0.0.spindir
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
Last edit: 15 Aug 2017 08:57 by timmert.
- photomankc
- Thank you received: 4
15 Aug 2017 12:50 #97502
by photomankc
Replied by photomankc on topic Spindle as speed counter clockwise.
Look at this:
linuxcnc.org/docs/2.4/html/hal_components.html#r1_2_1
You can feed the RPMs into that and it's output should always be a positive value. I'm not sure exactly where in your HAL that would need to be placed.
linuxcnc.org/docs/html/examples/spindle.html
That link explains how spindle-at-speed can be setup so you can probably look through your HAL to see how it's done and where to insert the ABS component to eliminate the sign.
15 Aug 2017 13:19 #97505
What drives your spindle-at-speed input?
You probably have motion.spindle-speed-out-abs connected to the hardware with separate fwd.rev logic.
It is likely that a "wcomp" or "near" component is being used to compare the spindle speed feedback from the encoder to the commanded speed, but it is probably looking at the absolute version of the commanded speed.
The simplest answer is probably to connect the "near" to motion.spindle-speed-out-rps instead, which is a positive/negative number matching the encoder velocity output scaling and sign.
Replied by andypugh on topic Spindle as speed counter clockwise.
Hi
How to solve this?
15 Aug 2017 13:50 - 15 Aug 2017 13:55 #97513
by timmert
I do use the near component
Not sure anymore how to edit it
net spindle-vel-cmd-rps => near.0.in1
net spindle-vel-fb-rps => near.0.in2
net spindle-at-speed motion.spindle-at-speed <= near.0.out
setp near.0.scale 1.10
Last edit: 15 Aug 2017 13:55 by timmert.
15 Aug 2017 14:07 #97516
OK, that HAL looks right to me.
Can you monitor near.0.in0 and near.0.in1 with halmeter and tell us the numbers at 500rpm fwd and 500 rpm reverse?
15 Aug 2017 14:14 #97517
by timmert
I don't see a near 0.in0 in the halmeter
I can see a near 0.in1 and 0.in2
0.1
CW 500RPM = 8.33333....
CCW 500RPM = - 8.3333...
0.2
CW 500RPM = 8.5
CCW 500RPM = 8.5
0.1
0.2
CW 500RPM = 8.5
CCW 500RPM = 8.5
15 Aug 2017 15:09 #97519
This seems to say that spindle-vel-fb-rps does not go negative when the spindle reverses.
That is directly linked to the encoder, so that seems to indicate that the encoder only shows positive numbers.
And this is why:
Do you only have a single-pulse spindle encoder by any chance? (Do you have index?)
counter-mode can's sense direction. If you do have a proper quadrature encoder then set that to 0.
If you don't have a quadrature encoder then one solution is to use:instead of the current net.
A better solution is to fit a proper encoder, so you can do rigid tapping.
0.1
0.2
CW 500RPM = 8.5
CCW 500RPM = 8.5
And this is why:
setp hm2_5i25.0.encoder.00.counter-mode 1
net spindle-vel-cmd-rps-abs=> near.0.in1
The following user(s) said Thank You: timmert
16 Aug 2017 07:45 - 16 Aug 2017 07:46 #97551
by timmert
Thanks Andy, it's working!
I have an index single and 150ppr encoder
It's a (rotary?) encoder connected to the spindle with a belt.
What do you recommend?
A index and quadrature encoder?
Last edit: 16 Aug 2017 07:46 by timmert.
16 Aug 2017 09:07 #97555
I would be surprised if the encoder is a single channel + index? Do you have the B-phase connected?
Time to create page: 0.114 seconds
