Spindle as speed counter clockwise.
16 Aug 2017 09:14 #97557
by timmert
Replied by timmert on topic Spindle as speed counter clockwise.
It's an emco lathe encoder
It has index and 150ppr
the 150ppr is connected to phase a
I dont have a phase b
17 Aug 2017 14:28 #97626
Replied by andypugh on topic Spindle as speed counter clockwise.
OK, that's enough for threading but not tapping.
If you have an index then there is no reason to change it unless you want tapping (and that's not anything I have felt the need for yet)
17 Aug 2017 14:32 - 17 Aug 2017 14:33 #97627
by timmert
If I want tapping function in the future. I need a quadrature right? with Index? How many PPR?
Last edit: 17 Aug 2017 14:33 by timmert.
17 Aug 2017 14:38 #97630
Single-point threading can work with only one pulse, and the 150 you have now is more than enough. Tapping needs to have an accurate idea of exactly when the spindle reverses, so you want to have less space between counts than you can risk mis-rotating a tap by. (and 150 is probably fine there too).
You can single-point most threads that you can tap.
The following user(s) said Thank You: timmert
Time to create page: 0.219 seconds
