cnc ramps up and down on each line of code
06 Sep 2017 20:04 #98598 by Les91
I am making parts that have straight lines and arcs on the outline. My machine ramps up and down for each object. Is there a function to make the machine run continuously around the periphery of the part.
Thks
Les91
06 Sep 2017 20:18 #98599 by Todd Zuercher
You can do this with O-codes.
linuxcnc.org/docs/html/gcode/o-code.html#ocode:repeat
And within them there are at least 3 different ways to do it, While Loops, If Conditionals, or simple Repeats.
A while loop seems like the obvious choice for this. For example if your code lowers the tool an amount per pass, simply set up your while loop to run until the depth is equal to your desired final depth.
The following user(s) said Thank You: Les91
08 Sep 2017 14:52 #98692 by andypugh
What "ramps"? The Z-height? The spindle speed? The axis velocity?
Which version of LinuxCNC?
Time to create page: 0.073 seconds
