Errors preventing LinuxCNC from starting.
28 Sep 2017 14:16 #99551
Replied by PCW on topic Errors preventing LinuxCNC from starting.
The easiest way is to download and install the Debian Stretch test ISO:
www.linuxcnc.org/testing-stretch-rtpreem...-uspace-amd64-r8.iso
This has the advantage that it contains the required uspace version of LinuxCNC, plus a recent Preempt-RT kernel
so is an especially good choice if you have newer PC hardware. It has the disadvantage that there may be some problems with some LinuCNC GUIs that depend on Glade (gmoccapy is one example)
Another way is to start with a Debian Wheezy distribution and install the Preempt-RT kernel and LinuxCNC uspace package:
linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel
This is a better choice for older hardware, and should not have any GUI issues since is the same distribution
the current released version of LinuxCNC uses.
Yet another option is to install LinuxCNC from scratch on a Linux distribution like Ubuntu or Mint, here is a very long thread on this:
forum.linuxcnc.org/9-installing-linuxcnc...-or-deb?limitstart=0
The following user(s) said Thank You: cintsa cnc
- cintsa cnc
10 Oct 2017 15:00 #100145
by cintsa cnc
Replied by cintsa cnc on topic Errors preventing LinuxCNC from starting.
I have finally got the system up and running but the Ethernet board
lists an address of 192.168.1.121
According to the address on the machine it is "inet 192.168.10.101/24 and brb 192.168.10.255"
How am I able to change the address to match the board and allow Linux cnc created via the wizard to be operational?
- cintsa cnc
10 Oct 2017 15:02 #100147
by cintsa cnc
I meant to say the address on the computer running Linux CNC, not the CNC machine
10 Oct 2017 15:59 #100151
Replied by andypugh on topic Errors preventing LinuxCNC from starting.
192.168.1.121 is the default IP of the Meas Ethernet cards. Are you sure you are looking in the right place? (And what are you actually looking for?)
10 Oct 2017 16:11 #100153
192.168.10.101/24 is the host computers IP address range for connection to you local network,
probably assigned via DHCP.
The FPGA card cannot share this range and must have an independent connection and IP address range. That is, you cannot share the real time LinuxCNC Ethernet connection with general internet connections so if you want internet connectivity you must have 2 network interfaces on the host.
This can be done in a variety of ways. Some Motherboards have 2 Ethernet connections, an additional PCI/PCIE Ethernet card can be installed, a USB-->Ethernet dongle, a USB-WIFI adapter etc etc.
Once this is done you need to setup one network interface for internet access (this should normally be the USB/external card) and the other (usually motherboard) interface for connecting to the FPGA card
I would suggest using the FPGA cards 10.10.10.10 address rather than 192.168.1.121 as its less likely to overlap with common DHCP assigned NAT address ranges
There is a bit of information about manual network setup in the hm2_eth manual page. Note that this is not really linuxCNC related but just standard Linux network setup, I typically just set up the interfaces with the network manager GUI
10 Oct 2017 16:13 #100154
I don't think that you get one of those with Debian.
10 Oct 2017 16:57 #100155
I think its on all Debian derivatives (its certainly on Wheezy)
10 Oct 2017 18:57 #100159
Intere4sting, it is on my Stretch PC too. I am pretty sure it is absent from my actual machine PCs.
- cintsa cnc
17 Oct 2017 16:45 #100482
by cintsa cnc
Thank you for your support. I have found the GUi and entered the address mentioned, 10.10.10.10 but it also requires a net mask and gateway. how do i determine these?
- cintsa cnc
17 Oct 2017 16:48 #100483
by cintsa cnc
I have also moved the jumper on the board to enable EEPROM in the hope that works but no luck so far.
Time to create page: 0.096 seconds
