Errors preventing LinuxCNC from starting.
17 Oct 2017 16:51 #100484
Replied by PCW on topic Errors preventing LinuxCNC from starting.
You do not set the host address to 10.10.10.10 (that's the address of the FPGA card)
I would set the host address to 10.10.10.1 and netmask to 255.255.255.0
the gateway can remain blank
- cintsa cnc
17 Oct 2017 18:53 #100489
by cintsa cnc
Replied by cintsa cnc on topic Errors preventing LinuxCNC from starting.
I have done the changes but now notice on startup of Linux i get a message that is too fast to read but failed is in RED and and it says something about failed to start network.
17 Oct 2017 20:48 - 17 Oct 2017 20:49 #100490
Before even trying to start LinucCNC you should verify that you can ping the FPGA card
Can you post the results of these commands:
/sbin/ifconfig
uname -a
ping 10.10.10.10
/sbin/ifconfig
uname -a
ping 10.10.10.10
Last edit: 17 Oct 2017 20:49 by PCW.
- cintsa cnc
18 Oct 2017 18:29 #100521
by cintsa cnc
Attached is a PDF attachment listing the results as per your rquest
18 Oct 2017 18:40 - 18 Oct 2017 18:42 #100522
can you try just
ifconfig
Or if that doesnt work, try
ip a
ifconfig
ip a
Last edit: 18 Oct 2017 18:42 by PCW.
- cintsa cnc
18 Oct 2017 19:08 #100524
by cintsa cnc
alwyn@debian:~$ ifconfig
bash: ifconfig: command not found
alwyn@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 1c:1b:0d:8e:36:25 brd ff:ff:ff:ff:ff:ff
alwyn@debian:~$
alwyn@debian:~$
18 Oct 2017 19:17 #100525
Looks like you do not have enp1s0 configured for a static ip address of 10.10.10.1 and it also appears unconnected
- cintsa cnc
19 Oct 2017 18:34 #100560
by cintsa cnc
I am not very conversant with code so it would be greatly appreciated if you could supply the code necessary to connect the Ethernet. I would really like to get this system up and running as soon as possible.
19 Oct 2017 19:17 #100561
This is a network setup issue, not really coding
I would suggest reading through:
wiki.debian.org/NetworkConfiguration
- cintsa cnc
28 Oct 2017 15:42 #100934
by cintsa cnc
I have finally got Linux CNC configured to the MESA 7176E card and it it up and running.
There are however two other issues creating problems.
1). When I try use "gedit" nothing happens although it is listed in the ini. file. This tells me the app. was not iclude in the downloaded package, or need to be activated somehow.
If it was not included, is it possible to download it on a machine that has internet access and then transfer it to the Debian machine via USB.
The other question relates to "Axis". When I load the machine file created by using the config wizard, I get the followig error.
Error in -/.Axisrc
traceback (most recent call last)
File "/usr/bin/axis line 3513 in <module> execfile (rcfile)
File "/home/alwyn/.axis rc "line 3 in <module>
fullsize + maxgeo.split(' ')[03+'x' + maxgeo.split(' ')[1]
attributeError:('tuple' object has no attribute 'split'
There may be one or tw typo's in the above, but what does it relate to.
I am hoping you may be able to offer assistance in order to put this whole saga to rest.
Error in -/.Axisrc
Time to create page: 0.087 seconds
