Latency over 15.000.000 - before it was between 6000 and 7500
16 Sep 2017 12:26 #99033
by denhen89
Replied by denhen89 on topic Latency over 15.000.000 - before it was between 6000 and 7500
Alright, i think i now i know what the problem is. I need to add those 2 links/lines: deb buildbot.linuxcnc.org/ wheezy master-rt deb-src buildbot.linuxcnc.org/ wheezy master-rt
Iam just wondering if it will work with my processor because there reads "architectures: Wheezy (realtime with RTAI)
architectures: i386
But now amd64 like on the sim package.
Does that mean that it will not work with my cpu or so?
architectures: i386
16 Sep 2017 12:43 #99034
by denhen89
Just found out that i386 will work and just means 32bit version and not that its for intel cpus.
Sounds like i found the problem due to your help PCW. Thanks and later after the fresh install of linuxcnc and 2.8 pre i will post the results.
- Thank you received: 1369
16 Sep 2017 18:48 #99039
Replied by Todd Zuercher on topic Latency over 15.000.000 - before it was between 6000 and 7500
Where you went wrong was right here:
The repositories for master running the RTAI kernel should be:
3. Updated to 2.8 Pre (how i did it)
- opened Synaptic Packet Manager
- Settings → Repositories → "Other Software" Tab
- unchecked all links related to LinuxCNC
- added this 2 lines:
deb buildbot.linuxcnc.org/ wheezy master-sim
deb-src buildbot.linuxcnc.org/ wheezy master-sim
- closed the window and reload updates
- updated
deb http://buildbot.linuxcnc.org/ wheezy master-rt
deb-src http://buildbot.linuxcnc.org/ wheezy master-rt
16 Sep 2017 19:11 - 16 Sep 2017 19:26 #99040
by denhen89
Hello!
Yes Todd, that are the right one, because just 2 mins ago i got everything done and it works perfectly, so no Latency isssues anymore. Still, thanks for that!
Just one quick question to make sure that really everything is fine:
I tested the LinuxCNC sim config and everything works good, but then i started Stepconf Wizard and clicked forward all the time, because i have no cnc hardware (no Parallel card, etc.) attached.
When iam done and click on "my-mill" then i get many errors. (SCREENSHOT ATTACHED)
I think that is, because i have no hardware attached, right ?
Its maybe an stupid questions but i just want to make sure that this is an normal behavior if no cnc hardware is attached.
If so, then i can start to deinstall again everything, install windows, then Linux, and then my PC is ready for the CNC hardware which should arrive next week .
Thanks in advance.
Thanks in advance.
Last edit: 16 Sep 2017 19:26 by denhen89.
18 Sep 2017 12:23 #99079
If the computer has no LPT port, then a message like that would be expected.
18 Sep 2017 12:39 #99080
by denhen89
Perfect, thanks Todd. Tomorrow the pcie lpt card should arrive (moschip) and hope that it will work.
Thanks again.
Br,
Denis
Thanks again.
Br,
Denis
