ParPort Pins
16 Sep 2017 09:40 #99027 by joel0407
ParPort Pins was created by joel0407
Hey guys,
Just wondering if there is anyway to see ParPort input pins in Axis?
I'm setting up my homing switches and just trouble shooting at the moment. I can put my meter across the breakout board and see I am getting ground switched when home is tripped but just not sure how to check that I have HAL setup right.
16 Sep 2017 13:53 #99035 by raglanlittlejohn
Replied by raglanlittlejohn on topic ParPort Pins
In Axis, Machine /Show Hal Configuration /WATCH /Pins /parport /0 /pin-10-in (for first input). My parport inputs are pins 10 to 13 and pin 15. I had to supply 12v to the BOB for the inputs to work.
16 Sep 2017 15:00 #99036 by joel0407
Replied by joel0407 on topic ParPort Pins
Thanks mate, Much appreciated.
I've already supplied 12v to the BOB. Not sure it's working though as I get about 300mv from the proximity sensors when they are not tripped.
I'll check tomorrow afternoon. Of to bed now.
17 Sep 2017 00:40 #99042 by andypugh
Replied by andypugh on topic ParPort Pins
How have you wired the proximity sensors? Are they 2-wire or 3-wire? NPN or PNP?
17 Sep 2017 00:42 - 17 Sep 2017 00:43 #99043 by joel0407
Last edit: 17 Sep 2017 00:43 by joel0407.
17 Sep 2017 00:45 #99044 by andypugh
OK, so the proximity switch acts like a switch-to-ground between the black wire (output) and the blue (and) wire, and probably needs at least 6V on the brown wire.
Is that how it is wired? Id your BoB expecting +ve voltage inputs rather than switch-to-gnd?
17 Sep 2017 00:50 - 17 Sep 2017 00:54 #99045 by joel0407
Yep. 12v to Brown and Blue, Black wire to the BOB.
I have 2 motors on my Y axis and running Linux 2.8. Wires to ports 12 and 13. Just setting up homing in Y at the moment.
BOB expects switch to ground via the black wire.
When I put a meter across black wire and positive though, I get about 300mv. Once the switch is tripped, I get the full 12v. I'm a bit worried I have enough earth leakage that it's being detected as tripped when it is not.
Last edit: 17 Sep 2017 00:54 by joel0407.
17 Sep 2017 02:17 #99046 by andypugh
I wouldn't expect the inputs to trip at 0.3V
But you could put the multimeter on the output of the optometrist-coupler (if there is one) to be sure.
17 Sep 2017 11:43 #99052 by joel0407
This answer was perfect.
I can easily see that tripping the sensor isn't seen by the parallel port.
I can run a jumper wire directly from ground to the input on the BOB and see it change in Axis (from above reply). I can put my multi-meter from ve+ to the switched wire on the sensor and get 12v.
Not sure what's going on yet.
17 Sep 2017 12:38 #99053 by raglanlittlejohn
Good to know you got the input on the BOB working. Is the negative on the sensor (blue) connected to the ground of the BOB?.
Time to create page: 0.117 seconds
