corner pause for hot wire
- catalina752
22 Sep 2017 15:33 #99271
by catalina752
corner pause for hot wire was created by catalina752
I am trying to find out if linuxcnc has a corner pause feature to allow the middle of a hot wire to catch up before turning a corner. Without this feature, sharp corners would be cupped out in the middle of the cut due to the wire drag.
- Thank you received: 1369
22 Sep 2017 15:42 #99273
Replied by Todd Zuercher on topic corner pause for hot wire
If G61 (or G61.1) doesn't give you enough of a pause, then you may have to insert a G4Pn at each corner (n=the dwell time in seconds.)
- catalina752
22 Sep 2017 16:03 #99276
by catalina752
Replied by catalina752 on topic corner pause for hot wire
The problem is the delay needs to be configurable as it is dependent on cut length as well as material density. It is also dependent on the angle. It is also not practical to add a g4 command on a toolpath that has as many as 100 or more nested shapes
22 Sep 2017 16:34 #99279
I believe that the dwell time for g4 can be defined by a parametric variable. But that still needs you to stick them in and figure out a way to properly define your parameter. It should be possible to build something with G-code remapping that does what you want, but I don't think I'm clever enough to do it.
But as to whether Linuxcnc already has something built in that does exactly what you want, I think the answer is no.
03 Oct 2017 12:33 #99807
Replied by andypugh on topic corner pause for hot wire
An input filter that adds G4 commands on sharp corners ought to be possible too.
- catalina752
03 Oct 2017 15:08 #99815
by catalina752
I know that mach3 has it as well as flashcut. They are both systems that I have used in the past with cnc foam cutters
Time to create page: 0.066 seconds
