MESA 7i76 again another spindle out issue
29 Sep 2017 15:52 - 29 Sep 2017 15:55 #99625
by bevins
MESA 7i76 again another spindle out issue was created by bevins
I am pretty sure I am doing something incorrect but it is so simple I cannot find it.
with a 7i76 card spindle, I am using VFD and using the pot interface.
I cannot get anything out of the analog out pin.
I wired the 0, 10v and signal pin but I get no voltage out of the spinout. This should be a no brainer.....
I can see the rpm change when I am upping the RPM in Axis but no output.
Warning: Spoiler!
#INI FIle
OUTPUT_SCALE = 5000
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 5000
#HAL FILE
# ---digital potentionmeter output signals/setup---
setp hm2_5i25.0.7i76.0.0.spinout-minlim [SPINDLE_9]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i76.0.0.spinout-maxlim [SPINDLE_9]OUTPUT_MAX_LIMIT
setp hm2_5i25.0.7i76.0.0.spinout-scalemax [SPINDLE_9]OUTPUT_SCALE
net spindle-vel-cmd-rpm-abs => hm2_5i25.0.7i76.0.0.spinout
net spindle-enable => hm2_5i25.0.7i76.0.0.spinena
net spindle-ccw => hm2_5i25.0.7i76.0.0.spindir
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
Last edit: 29 Sep 2017 15:55 by bevins.
29 Sep 2017 16:07 - 29 Sep 2017 16:08 #99627
Replied by PCW on topic MESA 7i76 again another spindle out issue
Can you enable the spindle and have it set for some reasonable speed then read these parameters/pins
One way to show them is with the machine --> Show Hal Configuration -->Watch and select the pins/parms
another way is with halcmd:
halcmd getp hm2_5i25.0.7i76.0.0.spinout-minlim
halcmd getp hm2_5i25.0.7i76.0.0.spinout-maxlim
halcmd getp hm2_5i25.0.7i76.0.0.spinout-scalemax
halcmd getp hm2_5i25.0.7i76.0.0.spinena
halcmd getp hm2_5i25.0.7i76.0.0.spindir
(you could paste the above into a terminal window and run it as is)
Also check the VFDs 10V by measuring it at the 7I76 TB4 pins 1 (GND = bottom pin) and 3 (+10V)
Last edit: 29 Sep 2017 16:08 by PCW.
The following user(s) said Thank You: bevins
29 Sep 2017 16:14 #99628
by bevins
OK, I'll check that.
I did check for 10v on pins 1 and 3 on tb4 and it is there.
Replied by bevins on topic MESA 7i76 again another spindle out issue
30 Sep 2017 05:21 #99662
by bevins
Oops, my bad. Mispelled signal. All working now.
Thanks peter
Thanks peter
