- General
- General LinuxCNC Questions
- How to use linuxcnc with a real robot equipped with a absolute encoder ?
30 Sep 2017 03:36 #99658
by Zazakas
In linuxcnc,before to execute any G code the machine must be homed.
But for a robot with absolute encoder home is not needed , so how can I
deal with this home issue.
I mean after turn the machine on. How can I execute G code directly?
30 Sep 2017 04:15 #99659
Replied by PCW on topic How to use linuxcnc with a real robot equipped with a absolute encoder ?
Don't you just set NO_FORCE_HOMING?
The following user(s) said Thank You: Zazakas
30 Sep 2017 06:23 #99664
by Zazakas
Replied by Zazakas on topic How to use linuxcnc with a real robot equipped with a absolute encoder ?
Many thanks! Can't wait to try this out!
01 Oct 2017 02:18 #99713
by Zazakas
Ooops. It doesn't works as I expected.
take config : sim>axis>vismach>puma.ini for example:
After add NO_FORCE_HOMING=1 in Traj section,
When I want to switch to MDI mode or exectue G code ,
the AXIS gui tells me all joints must be homed before going into coordinated/teleop mode .
And I add a print line in the emctaskmain.cc file , the variable no_fore_homing is 1.
So where could be the problem?
01 Oct 2017 02:45 #99714
by Zazakas
yet how could linuxcnc know the initial joint position of the robot, if not homed?
01 Oct 2017 02:46 #99715
I just tried and it works (I can start gcode execution without homing)
01 Oct 2017 03:06 #99717
by Zazakas
ok,maybe something wrong with my config
I am in a rip environment and using like branch 2.8.0~pre1
how about yours?
Thanks again.
how about yours?
Thanks again.
01 Oct 2017 03:11 #99718
same, spelling error?
not editing the right file?
01 Oct 2017 03:39 - 01 Oct 2017 03:42 #99719
by dgarrett
For this development branch (git master) you will probably need to use the provisions for
absolute encoders as specified in the ini file:
Ref: linuxcnc.org/docs/devel/html/config/ini-...ome_absolute_encoder
(It looks like ([TRAJ]NO_FORCE_HOMING does not apply for non-identity kinematics
in the motion module even though task accepts it:Ref: github.com/LinuxCNC/linuxcnc/blob/677dc9...otion/command.c#L609
Replied by dgarrett on topic How to use linuxcnc with a real robot equipped with a absolute encoder ?
It is always important to state the branch.I am in a rip environment and using like branch 2.8.0~pre1
if (emcmotConfig->kinType != KINEMATICS_IDENTITY) {
if (!checkAllHomed()) {
reportError
(_("all joints must be homed before going into coordinated mode"));
emcmotDebug->coordinating = 0;
break;
Last edit: 01 Oct 2017 03:42 by dgarrett.
03 Oct 2017 05:56 - 03 Oct 2017 05:58 #99801
by Zazakas
Actually I am not sure about my branch.
And the absolute encoder option you pointed out works! No need to move the robot, although press home button is needed.
And do you have any idea how to move robot in joint space using G code or some other work programming language than can interface with linuxcnc ?
Last edit: 03 Oct 2017 05:58 by Zazakas.
- General
Time to create page: 0.377 seconds
