Basic Feeds and speeds Excel sheet
02 Oct 2017 09:46 #99762 by madguernseyboy
Hi all
I have been studying this subject a bit and spent some time to make a my own Feed rate calculator.
As a quick explanation I took chip loads i found online and put them all into a table. From this I interpolated a best fit graph for each material type including slow and aggressive.
Using this you are able to calculate a feed rate for any diameter cutter.
link to the excel sheet
greatful for any of your opinions to help me understand a learn.
Regards
Brendan
The following user(s) said Thank You: andypugh
Time to create page: 0.053 seconds
