Limit switches(again)
- Dustydevil
- Topic Author
11 Oct 2017 00:23 - 11 Oct 2017 00:25 #100188
by Dustydevil
Limit switches(again) was created by Dustydevil
Hello all.
Brand new to linux and baffled.
I did the motor setup yesterday with minor problems.
Trying to do homing but I keep getting an error.
'Exceeding positive soft limit on joint 2'
I have looked at the topic on the forum and the internet
(Seems a common problem).
I have tried many of the fixes but no joy.
No hair left.
I attach the ini and hal files.
Can someone have a look please.
No hair left.
Last edit: 11 Oct 2017 00:25 by Dustydevil. Reason: Add file
11 Oct 2017 00:43 #100191
Replied by PCW on topic Limit switches(again)
I'm no expert on homing but I'm pretty sure you are violating this:
From the LinuxCNC homing docs:
linuxcnc.org/docs/html/config/ini-homing.html
Note
The home switch location, as indicated by the HOME_OFFSET variable, must be strictly within the soft limits. That is, MIN_LIMIT < HOME_OFFSET < MAX_LIMIT.
- Dustydevil
- Topic Author
11 Oct 2017 03:28 - 11 Oct 2017 06:18 #100192
by Dustydevil
Replied by Dustydevil on topic Limit switches(again)
Thank you PWC.
So written out longhand it would read,
Max limit less than Home offset.
Home offset less than Max limit.
With numbers, Min limit -120. 0
Home offset -0.25
Max limit 0.0
I will try that this afternoon.
Home offset -0.25
Max limit 0.0
Last edit: 11 Oct 2017 06:18 by Dustydevil. Reason: Got Max/Min reversed
- Dustydevil
- Topic Author
11 Oct 2017 06:17 #100196
by Dustydevil
It worked.
Solved some other problems by searching the forum.
Progress at last.
Massive relief.
Progress at last.
Massive relief.
- Dustydevil
- Topic Author
11 Oct 2017 06:58 #100197
by Dustydevil
More progress.
Switch polarity sorted.
G30.1 set.
Attached updated .hal and .ini files.
G30.1 set.
- Dustydevil
- Topic Author
12 Oct 2017 05:16 #100256
by Dustydevil
I ran a program this morning, op1 only problem was at the end,
Programm finished without command error
op2. Different tool, touch off in Z, tried to run. An error came up about exceeding a limit.
Did a ref all home, X axis moved in the wrong direction.
Also, cannot mdi command while not homed error.
Will this happen every time I change tools.
Do I have to clear all offsets and how.
What is the correct way of setting a tool ?
Thought it would be a case of touching it on top of the work and pressing a button.
Must be missing something.
13 Oct 2017 12:45 #100320
Replied by andypugh on topic Limit switches(again)
It's close to that.
It might be instructive to look at the difference between Machine Position and Relative Position with each tool loaded, (and don't forget the G43)
It sounds like you might have a very big offset in one too. G10 in the MDI window can be more convenient than editing the tool table (in the background "touch off" does a G10 command)
- Dustydevil
- Topic Author
16 Oct 2017 07:39 #100426
by Dustydevil
Well it has taken a week but it finally works.
It seems it was holding on to an offset.
I put a G49 line in before the M30.
Now it works.
The reference in the wrong direction was a sticking home switch.
Looking forward to using it and learning.
Now it works.
Time to create page: 0.193 seconds
