Can I have a ONE AXIS cnc machine config?
13 Jul 2010 18:39 #3343
by ichudov
Can I have a ONE AXIS cnc machine config? was created by ichudov
I am retrofitting a Bridgeport Series II Interact 2 to EMC.
I have wired one axis with a servo drive, tach feedback, and a US Digital encoder.
What I would like to do, if possible, is to wire the servo motor and encoder on ONE AXIS ONLY and then try to debug as much as possible (encoders, soft limits, limit switches, homing, tuning etc), before turning my attention to other two axes.
That way, any possible mistakes I will make in only one place instead of three.
And my question is, does EMC support a "one axis CNC" machine configuration?
i
i
13 Jul 2010 22:06 #3345
by robh
Replied by robh on topic Re:Can I have a ONE AXIS cnc machine config?
it should be no problem todo,
in
[TRAJ] Section
AXES = n
One more than the number of the highest joint number in the system. For an XYZ machine, the joints are numbered 0, 1 and 2; in this case AXES should be 3. For an XYUV machine using "trivial kinematics", the V joint is numbered 7 and therefore AXES should be 8. For a machine with nontrivial kinematics (e.g., scarakins) this will generally be the number of controlled joints.
COORDINATES =
= X Y Z The names of the axes being controlled. X, Y, Z, A, B, C, U, V, and W are all valid. Only axis named in COORDINATES are accepted in g-code. This has no effect on the mapping from G-code axis names (X- Y- Z-) to joint numbers--for "trivial kinematics", X is always joint 0, A is always joint 4, and U is always joint 7, and so on. It is permitted to write an axis name twice (e.g., X Y Y Z for a gantry machine) but this has no effect.
see the intergrater manual for more options etc as im sure there are some i have missed
should get you started
rob
in
[TRAJ] Section
AXES = n
COORDINATES =
rob
Time to create page: 0.150 seconds
