Can EMC home on all three axis simultaneously
22 Jul 2010 12:28 #3451
by ichudov
Can EMC home on all three axis simultaneously was created by ichudov
My Bridgeport Interact CNC mill with a dead controller, that I retrofitted to EMC, is finally working -- it homes itself, and generally follows G codes.
I do need to tune it however, but that is for another post.
Here's a question: it now uses three home switches, one on each axis.
Is there some way to home all three axes simultaneously?
thanks
thanks
22 Jul 2010 13:18 #3454
by BigJohnT
Replied by BigJohnT on topic Re:Can EMC home on all three axis simultaneously
Take a look at HOME_SEQUENCE in the Integrators Manual in the Config section.
22 Jul 2010 14:01 #3456
by ichudov
Replied by ichudov on topic Re:Can EMC home on all three axis simultaneously
BigJohnT, thanks. It would seem that "home all" is supposed to work with every axis sequentially. So, if I set
AXIS_0
HOME_SEQUENCE=1
AXIS_1
HOME_SEQUENCE=2
AXIS_0
HOME_SEQUENCE=0
then EMC would first home X, then X, then Y, right?
Or can I set two axis with the same HOME_SEQUENCE number?
Would EMC then home them in parallel?
AXIS_0
HOME_SEQUENCE=1
AXIS_1
HOME_SEQUENCE=2
AXIS_0
HOME_SEQUENCE=0
22 Jul 2010 14:08 #3458
by ichudov
Oops, forget my question, I missed this sentence: ``If two axes have the same HOME_SEQUENCE, they can be homed at the same time''
Time to create page: 0.116 seconds
