Gmocappy fires relay twice
07 Sep 2019 03:34 - 07 Sep 2019 03:43 #144446
by bevins
Gmocappy fires relay twice was created by bevins
This is a weird one. Don't know what I am doing wrong. Really basic stuff. I am firing three relays with machine-is-on. They are used for various things but a major one is drive enable. The relays energize twice with Gmocappy. They click on, off then on again when I turn on the machine.
In Axis they don't do that. They just fire once.
Any ideas?
Any ideas?
Last edit: 07 Sep 2019 03:43 by bevins.
07 Sep 2019 03:38 - 07 Sep 2019 03:42 #144447
by bevins
Replied by bevins on topic Gmocappy fires relay twice
Here is a video showing this behavior.
#Gmocappy custom.hal
net machine-is-on hm2_7i92.0.7i77.0.0.output-00 hm2_7i92.0.7i77.0.0.output-01 hm2_7i92.0.7i77.0.0.output-02
#Axis custom.hal
Last edit: 07 Sep 2019 03:42 by bevins.
07 Sep 2019 06:49 #144458
Replied by cmorley on topic Gmocappy fires relay twice
what drives the signal 'machine-is-on'?
Chris M
Chris M
07 Sep 2019 11:42 #144469
by Arpad
Replied by Arpad on topic Gmocappy fires relay twice
I have the same problem after gmocappy 2.334 version
07 Sep 2019 12:27 - 07 Sep 2019 16:41 #144470
by bevins
When you press the on button in the gui.
Gmocappy version 3.08
/EDIT Sorry, halui,machine-is-on is driving machine-is-on.
Chris M
Last edit: 07 Sep 2019 16:41 by bevins.
07 Sep 2019 12:57 #144472
by JohnnyCNC
Replied by JohnnyCNC on topic Gmocappy fires relay twice
I had a similar problem in Axis when it was starting up. I used a debounce to solve the problem.
#This stops the relay that controls the 48volts from briefly clicking on while LCNC is starting.
net machine-ison halui.machine.is-on => vc-p4s.machine.ison debounce.1.0.in
# SSR 48Volt DYN4 Power
net mach-on debounce.1.0.out => hm2_5i25.0.7i76.0.0.output-02 hm2_5i25.0.7i76.0.0.output-04
07 Sep 2019 13:27 - 07 Sep 2019 13:53 #144473
by bevins
I am pressing a button in the gui. There should be no debounce problem there. IF there is it should be dealt with in the code for the gui.
I tried your example and that didnt work.
#This stops the relay that controls the 48volts from briefly clicking on while LCNC is starting. net machine-ison halui.machine.is-on => vc-p4s.machine.ison debounce.1.0.in # SSR 48Volt DYN4 Power net mach-on debounce.1.0.out => hm2_5i25.0.7i76.0.0.output-02 hm2_5i25.0.7i76.0.0.output-04
Last edit: 07 Sep 2019 13:53 by bevins.
07 Sep 2019 15:33 #144484
I think what Chris meant is: what drives the 'machine-is-on' signal in the hal file
Could you post your hal files?
Replied by PCW on topic Gmocappy fires relay twice
Chris M
The following user(s) said Thank You: bevins
07 Sep 2019 15:34 #144485
by bevins
When hitting estop it clicks twice also.
07 Sep 2019 15:58 - 07 Sep 2019 16:01 #144486
by bevins
Last edit: 07 Sep 2019 16:01 by bevins.
Time to create page: 0.255 seconds
