Axes not moving correct distance
- LinfieldGarage
- Thank you received: 11
27 Dec 2020 03:44 #193264
by LinfieldGarage
Axes not moving correct distance was created by LinfieldGarage
Hey all,
What factors outside of Linuxcnc can cause the axes to move the wrong distance?
I say it this way because I just built a new Linuxcnc install with the new 2.8 image, clean configuration using pncconf, on a totally different PC. I don’t see how it could possibly be the computer or software at this point.
I have been chasing this problem for a long time and have not put my new machine into service yet because of it,
The X axis moves .150 inch more than the commanded distance
The Y axis moves .120 inch more
The interesting thing is that the pncconf built-in axis testing feature moves the axes even more than the final working config does. It was moving about 2.5 inches for a commanded 1 inch move.
I am using made up numbers that work for these values, changing them makes no difference in the moves.
Dirsetup 10000
Dirhold 10000
Steplen 5000
Stepspace 5000
Acceleration and maxvel changes also don’t affect the move distance.
This is a gantry style plasma table, XYYZ design
Mesa 7i96 board
Keiling 5056e drives
Rack and pinion drives with 3:1 reduction
Cheap Amazon multi-voltage power supplies
Good wiring in a nice solid enclosure
Shielded wiring
Any help is appreciated.
Thanks,
Jamie
Dirsetup 10000
Dirhold 10000
Steplen 5000
Stepspace 5000
Mesa 7i96 board
Shielded wiring
Thanks,
Jamie
27 Dec 2020 04:20 #193265
Replied by PCW on topic Axes not moving correct distance
Is the motion consistent?
That is, after multiple motions, does a return accurately to a specific location?
- LinfieldGarage
27 Dec 2020 04:27 #193266
by LinfieldGarage
Replied by LinfieldGarage on topic Axes not moving correct distance
It is consistent.. I use a 2” dial indicator for testing and the indicator returns to zero every time.
Thanks!
Jamie
Thanks!
Jamie
27 Dec 2020 04:31 #193267
Replied by Aciera on topic Axes not moving correct distance
So the extra distance is the same regardless of the commanded distance or is it larger for longer distances?
If the latter is the case you would need to adjust your STEP_SCALE in the INI file.
- LinfieldGarage
27 Dec 2020 04:43 #193268
by LinfieldGarage
That is a great question, I don’t remember so I will re-test in the morning.
Is it normal to have to “tune” the step_scale number? I used math to determine the correct step_scale, checked it with the gear reduction manufacturer, and both axes have identical motors, drives, and racks.
Thanks!
Jamie
Thanks!
Jamie
27 Dec 2020 05:51 #193270
Replied by rodw on topic Axes not moving correct distance
The missing value we need to help is details of your pinion. What module? How many teeth? how far does it move for one revolution?
On one of my axes, I had to resort to trial and error.
27 Dec 2020 06:07 #193271
I usually divide the commanded distance by the the actually measured distance travelled and multiply that with the STEP_SCALE used.
- LinfieldGarage
27 Dec 2020 16:05 #193298
by LinfieldGarage
Thank you all for the help.
@rodw I am using the rack and pinion drives below. They have a 20 tooth stepper pulley and a 60 tooth pulley driving the rack gear.
www.finelineautomation.com/product/rack-and-pinion-drive/
With 8x micro stepping step_scale should be:
(8 micro steps per step * 200 steps per rev * 3 gear reduction) / (1in pitch diameter * pi) = 1,527.88745 steps per inch
@Aciera and PCW, after lots of testing I believe this is a step_scale problem. The longer moves have more error and it goes past 0 on the way back. See table below.
Is it common to have to tune step_scale even when the math should be absolute?
Thanks again,
Jamie
Thanks again,
Jamie
27 Dec 2020 16:28 #193300
As I mentioned earlier you can calculate your step scale quite easily now for each axis:
STEP_SCALE = STEP_SCALE x "Expected Table Position" / "Actual Table Position"
Certainly not unheard of.Is it common to have to tune step_scale even when the math should be absolute?
- LinfieldGarage
27 Dec 2020 21:32 #193312
by LinfieldGarage
Great suggestion , I will give it a shot.
Time to create page: 0.171 seconds
