Serial communication for Encoder Feedback
I’m trying to communicate a Delta servo motor with Ormec Servo drive , but always I got F7 error , due to Feedback error .
I’m trying to connect the DB9 (feedback from delta servo motor ) with DB15 infeed for servo drive …
As we see I have two wire T+,T- ( I think RX , Tx) , Any body have an idea to advise …
- Thank you received: 5945
Not sure what is drive and what encoder type, so no further advice for now, more info or pictures would help.
The servo drive is Ormec , and the servo motor is Delta .. As I check in the manuals for both ,
1. serial communicate ,
2. Differential signals
attached some photos
Yes , Delta B2 is a servo drive , but it is compatible with the delta servo motor , I attached the photo ... ECMA type ..
I did a lot of searches , but I do not know how to get them communicate together ...
Try to find an incremental encoder that would fit inside the existing encoder housing, least expensive option.
I have Omron servos with serial encoders, and I just assumed the protocol is proprietary. But these drivers also support "fully-closed control" with linear scales connected directly to the drives, in addition to the motor encoders. There's a list of supported encoder types:
* "Encoder with 90° phase difference output" (I assume these are the normal "parallel" ABZ type encoders)
* "Incremental encoder with serial communications" (examples: Sony SR75, SR85)
* "Absolute encoder with serial communications" (examples: Mitutoyo AT573, ST771A, ST773A; Sony SR77, SR87)
This site lists the manufacurer of SR75 as Magnescale. Bought by or split from Sony perhaps?
Protocol (SR75) : Mitsubishi Electric, Panasonic, Yaskawa Electric
Output signal (SR75) : Incremental serial bidirectional signal, compliant with EIA-485
At least then it seems there's some kind of internal standard shared by these corporations? - Alas, no: looking at the detailed spec for SR75 the type designation is different for Mitsubishi, Panasonic, and Yaskawa support, respectively.
Hmm, I wonder if the Omron drives then supports all of these protocols?
On a related note, is there some standard for serial encoder signals?
There are indeed standards but the problem is that there are many. Some are open source like SSI and BiSS but I'd say most are proprietary. There are standards for Profibus, DeviceNet, Interbus, CANopen, EtherCAT, Profinet ...
Then you have manufacturers who don't want you to use encoders from other manufacturers and so they use their own closely guarded protocols they like to change slightly from one generation to the next.
pretty sure no. I dont know the omron driver but, serial communication and differenz signal are complete different.Hmm, I wonder if the Omron drives then supports all of these protocols?
Serial encoder data are packed and inside are individual functions of maker. To read this data it s neccescary to know the data inside and mostly only maker know this.
Second thing some serial data are wired with 4 cable two data two clock rate. Some with two one data one clock. I try to understand this but it seems my mind is not enough.
Result for me: buy driver and servo from one maker it saves much pain.
And Scales with differenz signal could you connect if your driver allowed to input differenz signal. Marked with A,A/ B,B/ Z,Z/
Forgot to mention, wiring stuff like that and hoping it works usually ends up in smoke and expensive paper weights.
