Double sided PCBs
28 Sep 2010 18:51 #4397
by miker
Double sided PCBs was created by miker
I'm wondering if anyone has had success using ECM2 to route double sided pcbs. On the software side of things I was wondering how routing of the bottom side is done once the top is routed.
28 Sep 2010 23:42 #4403
by BigJohnT
Replied by BigJohnT on topic Re:Double sided PCBs
I've not done pcb's but do multi sided machining every day. You just need some place to indicate from for both sides and indicate or probe the same surface. In some cases I'll make a sacrificial holder that has threaded holes and pins to locate the part from. Just depends on the part.
Time to create page: 0.073 seconds
