NC program Loaded By axis
24 Oct 2010 23:33 #4823
by 315john
NC program Loaded By axis was created by 315john
I would like to load a certian g code file as my default code file everytime i start EMC with axis. Can anyone help?
25 Oct 2010 09:45 #4827
Replied by andypugh on topic Re:NC program Loaded By axis
Look through the INI file in the config directory that you are usine, there is a line in there that defines the startup program.
in the [DISPLAY] section there is an OPEN_FILE entry, change that to be the full path to the program you want to open.
25 Oct 2010 09:52 #4829
by Rick G
Replied by Rick G on topic Re:NC program Loaded By axis
Hello,
Look in your .ini file and change the OPEN_FILE
OPEN_FILE = /full/path/to/file.ngc The file to show in the preview plot when AXIS starts.
Rick G
Rick G
25 Oct 2010 10:10 #4831
by Rick G
Andy typed faster than me.
Rick G
Rick G
26 Oct 2010 02:50 #4862
by 315john
Replied by 315john on topic Re:NC program Loaded By axis
Thank guys it worked!
My problem was i didn't put it under [DISPLAY] i guess cause it worked after i moved it.
I also have a question about classic ladder and modbus TCP/IP connection i will post under that forum
Time to create page: 0.175 seconds
