QtDragon_hd Qt Creator files
12 Feb 2024 05:17 #293128
by govind@89
QtDragon_hd Qt Creator files was created by govind@89
Could you kindly provide a link to download the Qt Creator files specifically tailored for QtDragon_hd? I'm eager to obtain them for my project.
12 Feb 2024 06:58 #293133
Replied by cmorley on topic QtDragon_hd Qt Creator files
The designer .ui file is here:
github.com/LinuxCNC/linuxcnc/tree/2.9/sh.../screens/qtdragon_hd
12 Feb 2024 07:40 #293135
by govind@89
Replied by govind@89 on topic QtDragon_hd Qt Creator files
Thank you very much! I have another question: How can I set an option to open all files with a specific software?
12 Feb 2024 07:56 #293138
I'm not sure what you mean.
Typically one would built the basic screen on designer, then run with linuxcnc to test and then edit the style file to get the look one wants.
12 Feb 2024 09:10 - 12 Feb 2024 10:19 #293144
by govind@89
Can the GUI be customized? If yes, which software should be used for editing and which file needs to be edited?
If I press home all button I just want to know which command is sent by Linuxcnc Gui and from which file.
which source file dependency for that GUI Commonds?
Last edit: 12 Feb 2024 10:19 by govind@89.
12 Feb 2024 13:59 #293149
Yes it can be customized in many ways.
Qt's Designer is the editor for the screen layout.
I use a text editor for the python code.
Here is documentation of the basic process:
linuxcnc.org/docs/stable/html/gui/qtvcp...._sheet_custom_screen
Home-all button calls the function btn_home_all_clicked() in the qtdragon_hd_handler.py file.
What is it you want to change?
12 Feb 2024 17:20 #293155
by govind@89
Thank you so much! I am thrilled to know that we can customize the GUI. I need to understand how GUI frontend to backend functions work and which functions are called to execute on those events and in which files.
Please guide me a few functions so that I can understand it better and make appropriate changes.
The ex.Home-all button calls the btn_home_all_clicked() function in the qtdragon_hd_handler.py file.
13 Feb 2024 07:01 #293201
Well there are several ways to use widgets to change linuxcnc state.
There are special widgets such as 'action_buttons' that are highly adjustable using properties.
If those don't suit you can do what the btn_home_all pushbutton did - call a function in the handler file.
A function like this:
ACTION is a library of commands to control linuxcnc. ie. ACTION.SET_MACHINE_HOMING(-1) tell linuxcnc to home all the joints.
If you ask specific questions I can give specific answers.
Chris
def btn_home_all_clicked(self, obj):
if self.home_all is False:
else:
# instantiate dialog box
info = "Unhome All Axes?"
mess = {'NAME':'MESSAGE', 'ID':'_unhome_', 'MESSAGE':'UNHOME ALL', 'MORE':info, 'TYPE':'OKCANCEL'}
ACTION.CALL_DIALOG(mess)
Chris
13 Feb 2024 08:22 #293204
by govind@89
Thank you very much for responding. Could you kindly inform me about which file supports the labels or buttons in the GUI at the GUI level, and which file executes that gui buttons commond the corresponding event at the Firmware level.
the location of these files?
14 Feb 2024 08:16 #293301
This is the base folder for widget and libraries used in Qtvcp:
github.com/LinuxCNC/linuxcnc/tree/2.9/lib/python/qtvcp
Here is action buttons:
github.com/LinuxCNC/linuxcnc/blob/2.9/li...ets/action_button.py
This is the file that sends commands to linuxcnc (using the python linuxcnc module):
github.com/LinuxCNC/linuxcnc/blob/2.9/li...n/qtvcp/qt_action.py
