Operaor Error With raspberrypi
- Abdulkareem
17 Apr 2024 15:22 #298456
by Abdulkareem
Operaor Error With raspberrypi was created by Abdulkareem
17 Apr 2024 15:58 #298457
Replied by PCW on topic Operaor Error With raspberrypi
That indicates a real time issue on the RPI
Have you run a latency test?
- Abdulkareem
18 Apr 2024 11:00 #298545
by Abdulkareem
Replied by Abdulkareem on topic Operaor Error With raspberrypi
18 Apr 2024 11:20 #298548
by cornholio
Replied by cornholio on topic Operaor Error With raspberrypi
It's going to help if you can describe your system, are you using ethernet, SPI or gpios (software steeping). Mesa, remora or other hardware.
Your HAl & INI files will help as well.
- Abdulkareem
18 Apr 2024 12:27 #298551
by Abdulkareem
i am using ethernet and mesa 7i96s
18 Apr 2024 14:23 #298560
Typically with a RPI4 you need to
set the force_turbo option true (in config.txt)
set isolcpus to 2,3 (in cmdline.txt)
You may also need to lower the servo thread
period to 2ms (2000000)
The following user(s) said Thank You: Abdulkareem
- Abdulkareem
21 Apr 2024 15:04 #298781
by Abdulkareem
How to lower the servo thread period?
21 Apr 2024 15:09 #298784
Change
SERVO_PERIOD = 1000000
to
SERVO_PERIOD = 2000000
to
The following user(s) said Thank You: cornholio, Abdulkareem
21 Apr 2024 15:10 #298785
by cornholio
Change in your ini file
to
to
- Abdulkareem
06 May 2024 10:37 #299929
by Abdulkareem
I was wondering if I used a mini industrial PC, will I get higher speeds
Time to create page: 0.314 seconds
