punching machine
21 Jan 2011 10:36 #6789
by anpe
Replied by anpe on topic Re:punching machine
Another question
When I write in my hal file the string "setp wcomp.1.max 5.0" - it works ok, but when I try write "net LubeStrike => wcomp.1.max" emc says : wcomp.1.max does'n exist
Where am I wrong?
Where am I wrong?
21 Jan 2011 11:24 #6790
by BigJohnT
Replied by BigJohnT on topic Re:punching machine
It's kinda hard to guess with just one line of code.
21 Jan 2011 12:14 #6792
by anpe
I can not post my code now because I'm not near my machine.
If I write "net LubeStrike => oneshot.1.width" it works.
as written in manual wcomp.max and oneshot.width are float both
21 Jan 2011 12:18 #6793
by BigJohnT
Open up Show Hal Configuration and view the pin to make sure your spelling is correct.
21 Jan 2011 14:26 #6797
by anpe
The problem solved by changing wcomp to comp
23 Jan 2011 16:51 #6810
Replied by andypugh on topic Re:punching machine
anpe wrote:
This might be only a partial solution, as the two components do different things.
The underlying problem is that wcomp.N.max is a parameter, not a pin.
A parameter is stored in the internal memory of the component. It can be set by setp, but is not available to other components.
A pin is stored in global shared memory, and its value can be read and/or written by other components. In fact what the "net" command does (I think) is simply arrange for all the components to use the exact same bit of memory to read/write the pin value.
I think that a solution in your case (if you do want to use wcomp) would be to run a "halcmd setp" command in a script, called by a custom M-code.
linuxcnc.org/docs/html/gcode_main.html#sec:M100-to-M199:
10 Feb 2011 06:45 #7102
by anpe
My machine is almost finished and it works.
Thanx to Rick G, BigJohnT, andypugh for your help.
I've uploaded some photos and video at det-sadik.com/info (sorry for quality)
10 Feb 2011 11:14 #7107
by Rick G
Replied by Rick G on topic Re:punching machine
Glad to hear you are up and running!
Rick G
Rick G
Time to create page: 0.236 seconds
