A homing problem...
11 Jan 2011 20:32 #6633
by nursum
A homing problem... was created by nursum
Hello,
when I home my machine (with servo drives) it stop at: X=0.016mm Y=0.022mm Z= -0.019mm A=359.991 for example. The "home" and the "home offset" are both set to zero at the ini-file for all axes. When I move with G00 X10 Y10 for example, the machine goes to X=10.016mm and Y=10.022mm and not to X=10.000mm! How can I tell the machine that the zeropoint is zero and not 0.016? Maybe it is a small thing but I can't find a solution... the "home offset" have no effort.
Ingo
Ingo
11 Jan 2011 21:23 #6635
by BigJohnT
Replied by BigJohnT on topic Re:A homing problem...
I'd bet you have an offset in effect. In the machine menu there is one to clear offsets.
11 Jan 2011 21:45 #6636
Replied by andypugh on topic Re:A homing problem...
Press # ?
I think you are seeing actual feedback position rather than commanded position.
You might be able to get closer with tuning (perhaps a bit of I)
- willburrrr2003
26 May 2011 03:42 #10080
by willburrrr2003
Replied by willburrrr2003 on topic Re:A homing problem...
Was playing with homing lastnight, as I just got home and limit mounted on my Z axis. I had the same thing happen, and realized that it was after I touched off on my part and set coordinate to 0.0 . Had to clear my part coordinate (offset?) before the machine would home to machine Z0.0. it was under the Machine menu.
Regards,
Will
Regards,
Will
26 May 2011 09:41 #10083
willburrrr2003 wrote:
This might shed some light on the situation:
wiki.linuxcnc.org/emcinfo.pl?CoordinateSystems
I think you might be confusing machine coordinates with relative coordinates.Had to clear my part coordinate (offset?) before the machine would home to machine Z0.0. it was under the Machine menu.
