Upgrading from 8.04 to 10.04 conversion issues.
07 Feb 2011 12:52 #7050
by greeder88
Upgrading from 8.04 to 10.04 conversion issues. was created by greeder88
I installed 10.04 next to my 8.04 on the same computer which I am glad I did. Now I can try both back and fourth. The issue I found is I cannot copy and paste my highly modified 8.04 files into 10.04 and get them to work. I have a nice pyVCP setup and JOG Pendant I have to get into 10.04 and they don't exactly convert over. Anyone know where the issues are? I find 10.04 is not really much of an improvement so I don't want to spend much time starting from scratch. It is nice to have the latest and greatest though.
07 Feb 2011 21:07 #7057
Replied by cmorley on topic Re:Upgrading from 8.04 to 10.04 conversion issues.
It would help if you told us what the error is and what version of EMC was the 8.04.
08 Feb 2011 01:58 - 08 Feb 2011 02:49 #7062
by greeder88
Replied by greeder88 on topic Re:Upgrading from 8.04 to 10.04 conversion issues.
My 8.04 is version 2.3.5
Can I overwrite the latest version configuration files with my configuration files from 2.3.5? I compared file univpwm servo hal and both versions are identical. I am checking others but a long tedous process.
I checked each file and:
univpwm-tbl is different between versions
univpwm-var is missing in 10.04
emc-nml is missing in 10.04
What should I do with these three differences to upgrade my old configuration files to the new version?
Maybe leave the -var and -nml files out? I am guessing that I need the -tbl file?
Last edit: 08 Feb 2011 02:49 by greeder88.
- step4linux
- Thank you received: 5
08 Feb 2011 07:17 #7066
by step4linux
Replied by step4linux on topic Re:Upgrading from 8.04 to 10.04 conversion issues.
Delete the line with nml file in your ini.
More details see here:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?UPDATING
Time to create page: 0.127 seconds
