Cutting mirror image?
15 May 2011 17:23 #9825
by Tom1965
Cutting mirror image? was created by Tom1965
I'm new to this stuff and reading the posts. I've learned that you have to think backwards sometimes, with table directions +/- and such. But my first cut of the eample "EMC2 4 AXIS" cut in a mirror image? Weird. I'm using a motion24 Gantry table from Mekanika that I have mounted a Bosch palm router to. Any ideas what would cause this?
thanks in advance for any thoughts.
15 May 2011 17:50 - 15 May 2011 17:52 #9826
by PKM
Replied by PKM on topic Re:Cutting mirror image?
You need to change X and/or Y direction.
When X axis points right, Y axis should point forward, Z axis up. You should have corresponding movements of tool over workpiece when pressing + and - axes buttons in manual mode.
Last edit: 15 May 2011 17:52 by PKM.
15 May 2011 17:54 #9827
by BigJohnT
Replied by BigJohnT on topic Re:Cutting mirror image?
For a normal mill of any kind...
Plus X the tool goes right
Plus Y the tool goes away from you
Plus Z the tool goes up
15 May 2011 18:35 #9828
by Tom1965
Replied by Tom1965 on topic Re:Cutting mirror image?
Wow you guys are quick! Indeed the problem was in my "Y" axis polarity on the control board. I switched the wires and now cuts perfectly and corresponds to the screen image. Now I just have to think as negative as " tool toward material" only. Thanks again for the speedy reply. Is there any way to contribute to this program? I'm feeling kind of dirty using something for free. Can't find a donation button?
Tom
Tom
15 May 2011 22:34 #9834
by BigJohnT
We donate our time only... and help others when we can.
