7i43 and 7i48
11 Oct 2011 17:24 #13838
by ericson
7i43 and 7i48 was created by ericson
hi does anyone know if there is
a firmware for the 7i43 and 7i48
I have EMC2 2.5
I have EMC2 2.5
11 Oct 2011 17:44 #13839
Replied by PCW on topic Re:7i43 and 7i48
I know there's one for the 400K model:
freeby.mesanet.com/SVST6_6.BIT
freeby.mesanet.com/SVST6_6.PIN
11 Oct 2011 18:59 #13842
by ericson
Replied by ericson on topic Re:7i43 and 7i48
ok. will it works with pncconf.
11 Oct 2011 21:07 #13846
I dont think so
12 Oct 2011 00:19 #13851
Replied by cmorley on topic Re:7i43 and 7i48
The 7i48 uses muxed encoders, which PNCconf can partially handle.
PNCconf will only see the even numbered encoders, you would have to write HAL code if you want to use the odd numbered encoders.
If that is good enough for you I can make a file for you so you can use the firmware in PNCconf that Peter sent a link for.
12 Oct 2011 05:24 #13852
by ericson
it would be really nice
that would help me a lot
Thanks.
Thanks.
12 Oct 2011 08:08 #13855
first download this zip file and extract it on your desktop
12 Oct 2011 08:22 #13857
now If you have played with pncconf and saved a file pncconf adds a preference file its called:
.pncconf-preferences
if you haven't saved a file make a dummy one so this file is written.
after that load pncconf again and your firmware SVST6_6 should be available (chose 7i43-4 of course).
If there is a problem check that file.
Its a hidden file so to see it you must
click on show hidden' under 'view' in the file browser.
in that file there should be a line that looks like this:
<property name="customfirmwarefilename" type="string" value="~/Desktop/custom_firmware/firmware.py"/>
If not add it and try again.
12 Oct 2011 08:26 #13858
I forgot to mention, in case you didnt know to add the PIN file Peter sent you in the folder
/lib/firmware/hm2/7i43-4
probably need root access to do that
12 Oct 2011 20:50 #13871
by ericson
thanks for the reply.
but it does not work.
I added the bit file
and downloaded firmware.py
and extract it on the desktop.
I put the text in the file also,
if it was the right file?
Time to create page: 0.096 seconds
