7i43 and 7i48
13 Oct 2011 00:14 - 13 Oct 2011 00:16 #13873
Replied by cmorley on topic Re:7i43 and 7i48
when you extracted it was it still in the folder named custom_firmware ? It should be.
The text should go in the file named .pncconf-preferences
Then open pncconf from a terminal when the splash screen shows it should say
something like "Pncconf founf extra firmware"
it should also say something like:
/home/chris/Desktop/custom_firmware/firmware.py
You are sure your using 2.5 ( hmm when did you get 2.5?)
Last edit: 13 Oct 2011 00:16 by cmorley.
13 Oct 2011 05:22 #13883
by ericson
Replied by ericson on topic Re:7i43 and 7i48
I have 2.5, but would perhaps not
download from buildbot.linuxcnc.org/ lucid master-rt
13 Oct 2011 05:24 #13884
Then you compiled it your self? Does the splash page in pncconf say alpha or beta1? (this is on the page it's self not in the terminal.
13 Oct 2011 05:57 #13885
by ericson
I'll check it out when I get home
in a few hours
in a few hours
13 Oct 2011 17:58 #13894
by ericson
finally it works
I had the beta1 version.
thank you for your help
14 Oct 2011 00:16 #13899
beta1 is good.
Hope it helps you out.
Let me know of any other problems.
16 Feb 2012 23:05 #17735
by PKM
Replied by PKM on topic Re:7i43 and 7i48
Hello!
I have the same hardware
BIT and PIN files copied to /lib/firmware/hm2/7i43-4
when starting Pncconf (beta 1 on compiled linuxcnc 2.6.0) I have
/home/pkm/Desktop/custom_firmware/firmware.py
**** PNCCONF ERROR: custom firmware loading error
Where should I look?
17 Feb 2012 03:14 #17747
pncconf has changed since then.
delete the custom_firmware folder from the desktop.
post your PIN file here and I will make a XML file for you.
The XML file goes were the BIT file went.
17 Feb 2012 06:46 #17749
try this xml file:
17 Feb 2012 08:45 #17750
by PKM
Thank you, Chris!
It works
It works
Time to create page: 0.126 seconds
