5i23 Amp enable doesn't move at all
11 Dec 2011 14:00 #15548
by jgnoss
5i23 Amp enable doesn't move at all was created by jgnoss
Hi all,
I use stepper Amps that need an enable signal to activate them.
In pncconf I configured 4 step generators on second connector to drive
the Amp's Step and Dir, as well as the Apmlifier Enable Signal and an
general e-stop.
The Point is, Amp Enable signals always stays high, doesn't matter what
e-stop or machine on is doing.
Somebody can lead me to what I'm doing wrong.
Ju
general e-stop.
Ju
11 Dec 2011 15:59 #15552
Replied by PCW on topic Re:5i23 Amp enable doesn't move at all
A little more information would be helpful:
Which FPGA configuration?
Which 5I23 I/O connector?
Which daughtercard? (and If daughtercard is used which I/O connection on the daughtercard is used for AMP Enable)
What GPIO bit is AMP enable?
Have you tried looking at this GPIO bit with HALMeter?
11 Dec 2011 17:18 #15558
by jgnoss
Replied by jgnoss on topic Re:5i23 Amp enable doesn't move at all
Sorry for the few information. I'm still new to all of that.
I have just a 5i23 installed in my PC.
No daughtercard.
I use a self made PCB to connect the 25 pin header to the connectors that fit my
stepper drivers.
I used pncconf in point and click style to configure the I/O's.
Selected the 5i23 and SVST4_8.
So stepgens show up on the second connector of the 5i23.
I used all of the four stepgens on that connector and the very next pin to Step / Dir of each stepgen as Output - "Amplifier Enable", further I configured an estop-in.
The e-stop worked well and showed expected results in Axis
but Enable pins on the connector didn't toggle on any action.
meanwhile I have installed EMC2 V2.5 and facing other problems.
So, let's go to the other thread.
Ju
No daughtercard.
stepper drivers.
Ju
11 Dec 2011 18:17 #15560
So can you put a HALmeter on the GPIO pin and see if its its toggling inside EMC?
11 Dec 2011 20:37 #15564
Replied by cmorley on topic Re:5i23 Amp enable doesn't move at all
if you can post the HAL file then I should be able to see whats going on. also what version of EMC is this?
12 Dec 2011 00:07 #15570
by jgnoss
Thank's cmorley,
As I wrote in the last post, that actually isn't the problem anymore.
Now I have updated to EMC 2.5.0-pre2-313-gdc2bde3
and there comes up the Errors I described in the
www.linuxcnc.org/index.php/english/compo...id=39&id=15551#15569
thread.
Maybe an admin can close this thread here, to don't get confused.
Ju
thread.
Ju
Time to create page: 0.292 seconds
