Errors Applying
26 Dec 2011 18:56 #15998
by SRT
Errors Applying was created by SRT
I just updated from the 2.5 branch and i am getting errors with PNCconf it will not allow me to apply the changes. Attached are the errors.
NCconf encountered an error. The following information may be useful in troubleshooting:
File "/usr/bin/pncconf", line 8009, in on_complete_finish
self.data.save()
File "/usr/bin/pncconf", line 3303, in save
self.write_halfile(base)
File "/usr/bin/pncconf", line 2545, in write_halfile
if needed:
UnboundLocalError: local variable 'needed' referenced before assignment
self.data.save()
if needed:
26 Dec 2011 20:55 #16000
Replied by cmorley on topic Re:Errors Applying
Yes I think I see the error.
Question - are you asking for an extra lowpass component?
If you also add a pyvcp or glade panel does the error go away?
Thanks Chris
Thanks Chris
26 Dec 2011 21:18 #16001
by SRT
Replied by SRT on topic Re:Errors Applying
I did add a Pyvcp and the problem presists. I don't know about the lowpass?
26 Dec 2011 21:29 #16002
this error should go away if you _do not_ have options:
include custom pyvcp gui panel
include custom gladeVCP panel
and I see that lowpass component is not on the HAL component page so that should not be a problem
Is this true?
Is this a config you created with a different version of PNCconf?
Is this true?
26 Dec 2011 21:32 #16003
ok I have got the error to show.
When you picked pyvcp option did you uncheck 'includehal connections'?
26 Dec 2011 21:39 #16004
by SRT
I might have? I tried so many things. I have used it before and was successful but I am working with resolvers and was trying to get a base layout for a lathe and keep it as clean as possible and add things later. I turned off the PYvcp and it did finish.
26 Dec 2011 21:39 #16005
by SRT
Beta 1 Version
26 Dec 2011 21:43 #16006
K. Thanks for the bug report. i will fix that soon.
Did you add an XML file that had resolvers on it?
PNCconf can configure resolvers but it needs the XML file.
I can make one for you if you have the .BIT file from Peter.
26 Dec 2011 21:43 #16007
by SRT
I just went back and tried it again. The include halinterface box is checked
26 Dec 2011 21:45 #16008
by SRT
I have the bit file. rmsvss6_8.bit
Time to create page: 0.146 seconds
