7i85s and muxed input encoders
20 Aug 2013 15:02 #37870
by casetero
7i85s and muxed input encoders was created by casetero
Hi there,
I´m using a 5i25 + 7i85s combo card. Untill now all worked nice with 2 stepgen´s and two encoders. But when i try to connect a third axis ( one more stepper and one more encoder) the problems start.
While running linuxcnc i type in a terminal "dmesg" and it just shows 2 inputs for encoders, it shows this:
3657.823974] hm2: loading Mesa HostMot2 driver version 0.15
[ 3657.827882] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3657.827930] hm2_pci 0000:02:02.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 3657.827935] hm2_pci: discovered 5i25 at 0000:02:02.0
[ 3657.828558] hm2/hm2_5i25.0: Smart Serial Firmware Version 38
[ 3657.885903] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3657.885908] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3657.885912] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3657.885915] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3657.885919] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 3657.885924] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Step (Output)
[ 3657.885933] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Direction (Output)
[ 3657.885937] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #1, pin Step (Output)
[ 3657.885942] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #1, pin Direction (Output)
[ 3657.885946] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #0, pin Step (Output)
[ 3657.885950] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #0, pin Direction (Output)
[ 3657.885955] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3657.885960] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #0, pin Muxed A (Input)
[ 3657.885964] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #0, pin Muxed B (Input)
[ 3657.885969] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #0, pin Muxed Index (Input)
[ 3657.885973] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #1, pin Muxed A (Input)
[ 3657.885977] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #1, pin Muxed B (Input)
[ 3657.885982] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 3657.885986] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3657.885989] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3657.885993] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3657.885996] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3657.886000] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3657.886003] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3657.886007] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3657.886010] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3657.886014] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3657.886017] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3657.886021] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3657.886028] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3657.886033] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3657.886036] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3657.886040] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3657.886043] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3657.886047] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
This is shown with 3 stepgens and 3 encoders.
The problem is that the system works nice with 2 axis ( X , Y ), but when i connect the third axis ( Z ), Z doesnt work and Y doesnt work too ( Y with 2 axis works). Sorry but my english is horrible.
I think the problem is due to the muxed inputs for the encoders. It works fine with 2 encoders but not with 3.
The dmesg file shown before, is correct if i put at the hal file that im working with 3 encoders??
Thank you very much.
20 Aug 2013 17:10 #37879
Replied by andypugh on topic 7i85s and muxed input encoders
What is your new "loadrt hm2_pci" line?
it is possible that you need to have 4 encoders, not 3 as the are muxed.
21 Aug 2013 05:56 #37910
Replied by PCW on topic 7i85s and muxed input encoders
Just to make sure there was not a driver issue,
I just checked a 5I25 /7I85S (7I85sx2 configuration),
and I dont see a problem with odd encoder numbers.
Tried 1,2,3,4 encoders enabled on the config line and all worked
as expected on at least two LinuxCNC versions (2.51 and 2.6.0-pre)
This might be a pncconf bug or maybe hardware/wiring
21 Aug 2013 18:01 #37922
by casetero
Replied by casetero on topic 7i85s and muxed input encoders
Thank you both,
It was a HAL code plus wiring problem. It works fine now with 3 encodes. I thought that should be the 3 inputs for encoders at the gpio of the 5i25 card.
Working with muxed inputs, there wont be any problem working with the 3 axis moving at the same time, will be??
Thanks and regards!!
22 Aug 2013 18:51 - 22 Aug 2013 18:55 #37962
No, there's no problem with interference between multiple muxed encoders
(we have customers using configurations with up to 48 (muxed) encoders)
Last edit: 22 Aug 2013 18:55 by PCW.
- HalaszAttila
- Thank you received: 5
05 Apr 2021 18:47 #204934
by HalaszAttila
Replied by HalaszAttila on topic 7i85s and muxed input encoders
Hello,
one more question about MESA 7i85S.
My configuration is:
5i25 + 7i76 (conn: P3) + 7i84 + 7i85S (conn: P2).
In to FPGA is flashed: 5i25_7i76_7i85s.bit
hm2_pci config=" num_encoders=5 num_pwmgens=1 num_stepgens=5 sserial_port_0=000000"
with this hm2_pci the Linuxcnc config is starts without error, and i can use the 7i85S-s encoder inputs, all 4 works.
My question is how to configure STEP/DIR outputs on 7i85S?
If i incrase the number of stepgens (num_stepgens = 9 => 7i76 (5pcs) + 7i85S (4pcs)) then i have the next error message:
insmod for hm2_pci failed, returned -1
Thanks.
Thanks.
05 Apr 2021 19:16 #204938
What does
sudo mesaflash --device 5i25 --readhmid
report?
report?
- HalaszAttila
05 Apr 2021 19:38 #204944
by HalaszAttila
Attached the result.
The 5i25 card is about 6-7 years old. If it matters.
The 7i85S is new.
The 7i85S is new.
05 Apr 2021 19:45 #204945
OK that looks right
What is the full error message?
- HalaszAttila
05 Apr 2021 19:51 #204946
by HalaszAttila
Time to create page: 0.163 seconds
