5i25+7i76 Spindle and Encoder Setup
04 Jan 2017 14:50 - 04 Jan 2017 14:50 #85213
Replied by andypugh on topic 5i25+7i76 Spindle and Encoder Setup
Are the 7i76 encoder inputs safe to 12V? Is the conditioning even necessary?
Last edit: 04 Jan 2017 14:50 by andypugh.
The following user(s) said Thank You: sg
04 Jan 2017 15:25 #85219
by sg
Replied by sg on topic 5i25+7i76 Spindle and Encoder Setup
Ok, Thanks for confirming. That's what I was assuming but I wanted to make sure. I'll play with the halmeter and see what hal signal I currently have for spindle enable.
I'll swap out and put in a lower resistance divider circuit to pull it closer to ground and see if I can get the Spindle Speed function to work.
PCW mentioned to me a few weeks ago that the A, B, and Index signals for the spindle must be 5V when wired into the 7i76.
Thanks for the help so far gents.
06 Jan 2017 12:43 #85332
by sg
I finally have both the spindle speed encoders and analog output working.
Thanks for your help once again.
Time to create page: 0.126 seconds
