Mesa 5i25 step by step configuration
23 Dec 2015 04:58 #67255
by Ozcnc
Mesa 5i25 step by step configuration was created by Ozcnc
Mesa 5i25 only.
I've been struggling to get my setup going and would like to ask if anyone would be able to guide me step by step.
I have a High Z S1400T Zero 3 setup that I have moved from Mach 3 to Linux.
I have installed the card and I have installed a fresh installation of Linux 2.7
I'm not sure how to assign the correct pin configuration.
Thanks,
Oz
Thanks,
Oz
23 Dec 2015 06:20 #67256
by Ozcnc
Replied by Ozcnc on topic Mesa 5i25 step by step configuration
So I've downloaded the 5i25 update and tried to "run in terminal", However there is only "open in terminal available".
I've tried to copy the files across but can't get permission.
I've tried sudo Nautilus and it asks me for a password, I type in my password and nothing happens.
Any suggestions.
Oz
Any suggestions.
Oz
23 Dec 2015 06:44 #67257
by Rick G
Replied by Rick G on topic Mesa 5i25 step by step configuration
Have you tried Pnccpnf wizard?
Rick G
Rick G
23 Dec 2015 06:57 #67258
by Ozcnc
Hi Rick,
I have tried PnCConf Wizard but not Pnccpnf Wizard.
I do see 5i25 but I need to load 5i25_dmmbob1x2 files.... I think....
23 Dec 2015 09:58 #67259
by cncbasher
Replied by cncbasher on topic Mesa 5i25 step by step configuration
have you a list of pin requirements , as to what you need for each pin ?
i presume your keeping the same pin configuration of mach 3 , if so , it may be helpful to also attach the mach3 xml
the 5i25 should have a sticker on the back saying what bitfile is already loaded ,
i'll help you get up and running , if you can send me or attach the above .
23 Dec 2015 09:59 #67260
by cncbasher
oh theirs no need to copy any files now as pncconf now has the 5i25 .
23 Dec 2015 12:23 #67263
by Ozcnc
Aha,
I've just learnt something.
I have never looked at the card its a 6i25 with 7i77x2.bit loaded.
I have attached the mach 3 xml file but please have a look at the zero3 manual attached.
I would like to use the pins 14,15,16, and 17 as well.
I want to use the additional cable/bracket hardware kit connector for reading my encoders on a second port that I still need to fit.
Thanks allot.
Oz
Thanks allot.
Oz
23 Dec 2015 14:36 #67266
Replied by PCW on topic Mesa 5i25 step by step configuration
The first step required is to reprogram the FPGA with the appropriate bitfile for the DMM BOB:
5i25_dmmbob1x2.bit
This is done with the mesaflash utility:
sudo mesaflash --device 5i25 --write 5i25_dmmbob1x2.bit
sudo mesaflash --device 5i25 --reload
then you can check the pinout with:
sudo mesaflash --device 5i25 --readhmid
if not there already, mesaflash is installed with
sudo apt-get install mesaflash
and 5i25_dmmbob1x2.bit is available in the 5i25.zip support file from Mesa
( in configs/hostmot2/ )
5i25_dmmbob1x2.bit
24 Dec 2015 07:57 #67283
by Ozcnc
Ok if flashed the card.
What's next.
Regards,
Oz
What's next.
Regards,
Oz
24 Dec 2015 17:27 #67292
The next step is to make a hal/ini file suited to the 5I25 card/daughtercard
There are a couple of different ways to do this
one is to start with a close pncconf created file pair
( The DMM bob is not directly supported but the probrfx2 is quite close so a pncconf created file set
using the 5i25/probrfx2 template should be close enough to get started with )
The other way is to start with the hm2-stepper sample config (and ini file)
I dont think there is a 5i25.ini file sample but you can take a 5i20.ini sample and just change the
card and file names.
Time to create page: 0.149 seconds
