Stepper configs have suboptimal P term setting
09 Feb 2016 00:17 #69800
Stepper configs have suboptimal P term setting was created by PCW
PnPConf created stepper configs use a initial P value of 50
This is much too low for stepper configs and will result in following errors (50 is ok as a starting point for servos)
For stepper configs, P should be 1/Servo-thread-period so P=1000 for the standard 1ms servo thread period
09 Feb 2016 01:08 #69806
Replied by cmorley on topic Stepper configs have suboptimal P term setting
Ok I will see what I can do
09 Feb 2016 01:22 #69807
I pushed a better fix into 2.7
steppers get a calculated P
servos get 50
This could still be screwed up if the user set the axis as a servo then changes to a stepper but its a little better.
Thanks for the heads up
Chris M
servos get 50
Chris M
09 Feb 2016 01:46 - 09 Feb 2016 01:48 #69808
Replied by PCW on topic Stepper configs have suboptimal P term setting
I think you may have the calculation wrong,
P should be 1/ servo-period-in-seconds, not servo period/1000
so P=1000 at 1 ms, 500 at 2 ms, 4000 at 250 usec
servo-period-in-ns/1000 is correct for 1 ms but wrong everywhere else
Last edit: 09 Feb 2016 01:48 by PCW.
09 Feb 2016 06:18 #69822
damn ok ill fix
09 Feb 2016 06:31 #69823
ok pushed a fix again.
Thanks for checking!
Chris M
Chris M
- guymalpass
11 Dec 2016 19:33 #83920
by guymalpass
Replied by guymalpass on topic Stepper configs have suboptimal P term setting
Hi Peter,
I'm running a closed loop stepper system using a 7i76, 7i77 and 5i25 and have recently noticed your post about P terms being 1/servo period. I have been using a P term of 170 so decided to try out 1000 (my servo period is 1000000) but I just get oscillation. Is there anything I should be looking at to explain why I am so far off your recommended value?
To clarify my stable settings are P-170 I-0 D-0 FF1-0.994 FF2-0.000025 on master branch.
Thanks,
Guy
Thanks,
Guy
11 Dec 2016 19:59 #83921
For a closed loop system (closed with encoder feedback)
1/T-servo is probably way too much P gain
because of delays from step output to physical motion
Only very tiny delays are present for "local" pid feedback so the 1/T-servo works and matches
the drivers position mode settings (that correct the position error completely in the next servo period)
- guymalpass
11 Dec 2016 20:08 #83922
by guymalpass
My mistake I thought the post was referring to closed loop setups.
11 Dec 2016 20:52 #83923
NP, I probably was not clear, its a bit confusing since they are both closed loop
(though one is closed locally to the stepgen position counter)
