pncconf with 5i25 and 7i77 and I need analog outs
16 Feb 2016 00:41 #70204
Replied by cmorley on topic pncconf with 5i25 and 7i77 and I need analog outs
yes thats the file i need thanks.
pwm outputs are the analog outputs. the 7i77 converts pwg to analog.
Yes the edits were easy, you could add them manually to what ever file you next make:
added:
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
loadrt scale names=scale.spindle
and:
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
addf scale.spindle servo-thread
Tool turrets are difficult to supply a sample for.
You didn't mention how the turret is indexed.
usually ladder logic is used for tool changes.
Chris M
added:
and:
Chris M
16 Feb 2016 00:59 #70205
by djs14
OK thank you.
I've managed to get the classicladder gui to come up when I load linuxcnc with some edits to the custom.hal file so I think I'm on my way. I imagine the ladder that I create will somehow get merged with the HAL file, etc.
Having a great time learning about all this stuff.
Thank you again,
Sean
Replied by djs14 on topic pncconf with 5i25 and 7i77 and I need analog outs
added:
and:
Chris M
OK thank you.
Thank you again,
Sean
16 Feb 2016 01:06 #70207
sorry could you post the pncconf file again but either change the ending to txt or zip it first?
Chris M
Chris M
16 Feb 2016 01:42 #70209
by djs14
I'm getting another error now when I'm trying to assign inputs:
input-oo does not exist
Here's the Hal file ... I commented out the input names I had assigned to see if it had anything to do with it.
16 Feb 2016 01:43 #70210
by djs14
Chris M
16 Feb 2016 02:20 #70211
As a work around if you select a gladvcp panel with spindle speed display the components will be added properly.
then you won't have to edit the file by hand.
On the screen page select 'include custom gladeVCP file' - The default options will be fine.
Chris M
Chris M
16 Feb 2016 03:02 #70212
Thanks for the bug report i have added a fix for this problem for the next release.
Chris M
Chris M
16 Feb 2016 03:39 - 16 Feb 2016 03:40 #70213
by djs14
Tried this but still getting an error when opening linuxcnc since I've started trying to define inputs:
pin '5i25.0.7i77.0.0.input-00' does not exist ... hal file pretty much the same as the one I posted above.
edit post 70209 above has hal file
Chris M
Last edit: 16 Feb 2016 03:40 by djs14.
16 Feb 2016 15:07 - 16 Feb 2016 15:08 #70236
Replied by PCW on topic pncconf with 5i25 and 7i77 and I need analog outs
(or similar)
Is expected if field power is not connected to the 7I77's isolated I/O section
(or similar)
Last edit: 16 Feb 2016 15:08 by PCW.
The following user(s) said Thank You: djs14
16 Feb 2016 16:03 #70241
by djs14
Thank you brother! Will hook up some power and hopefully see that message disappear.
Looking forward to playing with the ladder functionality.
Cheers all
(or similar)
Cheers all
Time to create page: 0.082 seconds
