mesaflash & pncconf
17 Feb 2016 04:09 #70274
by vre
mesaflash & pncconf was created by vre
With version 3.2 of mesaflash added new feature to output --readhmid --xml files.
Can i build in xillinx ise my custom bitfile flash it to mesa card after that generate xml with mesaflash
and load this xml to pncconf to generate my configs for linuxcnc ?
17 Feb 2016 04:12 #70275
Replied by cmorley on topic mesaflash & pncconf
possibly.
It's possible the XML from mesaflash is not quite compatible with pncconf. - It seems every XML converter does it differently.
Also if its a board that pncconf does not know about its not going to work.
What board are you trying to configure?
Chris M
Chris M
17 Feb 2016 04:46 - 17 Feb 2016 04:49 #70277
by vre
Replied by vre on topic mesaflash & pncconf
I have tested and pncconf does not read correctly the xml from mesaflash.
If worked this would be a killer feature...
Iam trying to configure 5i24 and here is the xml mesaflash generated
Last edit: 17 Feb 2016 04:49 by vre.
17 Feb 2016 05:25 #70278
Sorry the 7i24 is not supported n pncconf right now.
You could probably use a 5i25 config (with the same firmware type) then change all the names from 5i25 to 5i24
Chris M
Chris M
18 Feb 2016 08:22 #70336
by vre
Are there any plans for supporting 5i24 in future?
19 Feb 2016 04:06 #70363
My interest in upgrading pncconf is stalled at this time.
I have a version that uses mesaflash to read the card but there are some usability issues to deal with.
It is a very lot of continuous work with little up side for me.
I'm sure I will pick it up again soon.
So yes eventually.
Chris M
So yes eventually.
Chris M
Time to create page: 0.106 seconds
