Installing and checking firmware on mesa 5125
27 Feb 2016 20:38 #70730
by Ncmill.ts
Replied by Ncmill.ts on topic Installing and checking firmware on mesa 5125
ok i will try to update to newer linuxcnc,my linuxcnc computer is not hooked up to the internet at the moment so if there is
a updatefile that can be downloaded ill try that.
thank for your support and Quick reply.
28 Feb 2016 18:12 #70757
by Ncmill.ts
hi again i have installed linuxcnc debian wheezy 2,7,0 (live cd).
sins there is no folder for 5125card under "lib/firmware/hm2/ i have downloaded 5125.zip from mesa homepage and unzipped it.
i am atempting to copy it to hm2 folder but unable to ,problems with permission i suspect.
owner: root(Root) unable change it .
how do i change it (i did not get sudo nautilus to work,does not accept my password and the only one i know about is the one i use when i start my computer and log in.
any ideas??.
any ideas??.
28 Feb 2016 18:25 #70759
Replied by PCW on topic Installing and checking firmware on mesa 5125
I would just unzip the 5i25.zip file in your home directory
there is no point in installing it anywhere permanent
28 Feb 2016 18:33 #70760
by Ncmill.ts
????why not installing it where all the other firmwares are,is not that that the proper way?.
28 Feb 2016 19:01 #70761
by Ncmill.ts
hi i have manage to flash my 5125 card thru Root terminal ..mesaflash etc.
im asked to do powercycle with the --reeload command.
how do i type this in terminal window??
28 Feb 2016 19:05 #70762
if you do the
you do not need to power cycle
mesaflash --device 5i25 --reload
04 Apr 2016 22:32 #72746
by dinodf
Replied by dinodf on topic Installing and checking firmware on mesa 5125
Hello,
from LinuxCNC 2.5 to LinuxCNC 2.7 I have to re-flash mesa's cards?
Thank you
Dino
Thank you
Dino
04 Apr 2016 22:39 #72748
No
The following user(s) said Thank You: dinodf
Time to create page: 0.108 seconds
