Jog speed is very slow
12 Mar 2016 19:36 #71500
by Clive S
Replied by Clive S on topic Good enough reasonJog speed is very slow
Good enough reason Thanks Clivestepconf does not support Mesa cards so it won't work for you.
Chris M
29 Mar 2016 13:41 #72323
by Amedee
Thank you!
I scratched my head the whole evening yesterday with that -- beyond the speed it now sets the FERROR accordingly.
The 'Imperial FERROR' was generating strange moves in pncconf (axis going backwards after a jog move) and also gave 'Joint 0 following error' while homing in LinuxCNC.
I pulled the latest version this morning and it now works as expected.
Note that there is a typo in the comments , it should be 360, not 380
Also, as I was wondering why the maximum values in the UI didn't change proportionally, I realized they where hard-coded in screen.glade, and by cranking up the values for the metric folks, we get very big ranges in the imperial system.
Shouldn't we set the range dynamically based on the system chosen? -- something like:
(Also instead of maintaining 2 sets of values imperial/metric, we could just extrapolate the metric ones from imperial)
Replied by Amedee on topic Jog speed is very slow
well I pushed fixes to pncconf to set more reasonable defaults for metric and angular jogs.
will be included in 2.7.5
Thank you!
--- bin/pncconf.orig 2016-03-29 10:43:24.506867501 +0200
+++ bin/pncconf 2016-03-29 13:21:50.975355007 +0200
@@ -797,6 +797,7 @@
if units: # imperial
# set GUI defaults
self.max_linear_velocity = 1 # 60 inches per min
+ self.max_linear_velocity_range = (0, 100)
self.default_linear_velocity = .25 # 15 inches per min
self.min_linear_velocity = .01667
@@ -818,7 +819,8 @@
else: # metric
# set gui defaults
self.max_linear_velocity = 25 # 1500 mm per min
- self.default_linear_velocity = 6 # 380 mm per min
+ self.max_linear_velocity_range = (0, 2500)
+ self.default_linear_velocity = 6 # 360 mm per min
self.min_linear_velocity = .5
# axes defaults
--- lib/python/pncconf/pages.py.orig 2016-03-29 12:16:23.136734626 +0200
+++ lib/python/pncconf/pages.py 2016-03-29 13:25:24.296673195 +0200
@@ -408,6 +408,7 @@
self.w.max_spindle_override.set_value( self.d.max_spindle_override*100)
self.w.min_spindle_override.set_value( self.d.min_spindle_override*100)
self.w.max_linear_velocity.set_value( self.d.max_linear_velocity*60)
+ self.w.max_linear_velocity.set_range(self.d.max_linear_velocity_range[0],self.d.max_linear_velocity_range[1])
self.w.min_linear_velocity.set_value( self.d.min_linear_velocity*60)
self.w.default_angular_velocity.set_value( self.d.default_angular_velocity*60)
self.w.max_angular_velocity.set_value( self.d.max_angular_velocity*60)
01 May 2016 10:11 #74102
by epineh
1500mm/min is still pretty slow, I would put it at least 5000mm/min, or better yet 15000mm/min.
The value can always be reduced in Pncconf below the max but not above and any manual change will be wiped on next run of Pncconf.
380mm/min is probably a nice slow speed for the default value.
Cheers.
Russell.
Replied by epineh on topic Jog speed is very slow
would 1500 mm/m for max jog velocity and
380 mm/m for default jog velocity
Be reasonable metric defaults?
Chris M
Cheers.
Russell.
Time to create page: 0.076 seconds
