Servo Jog PNCCONF Open loop test
12 Mar 2016 01:45 #71469 by marsheng
I did post this earlier in Setup but I think it should be here.
I'm running MESA 7I48 and servo drives and motors. The encoder is on the back of the motor. If I turn the motor, CC or CCW by hand, I get the axis value incrementing on the DRO. When using the test in the config program and stepping the motor, I get a nice smooth rotation, around 3 rpm in the CCW direction, however I get about 300 rpm in the CW direction.
I have put a meter on the input to the Servo card and this is what I have.
CW a pulse around 0.5 volt The hm2_5i20_0_encoder.00.position increments by 2 units
CCW around 5 volt. The hm2_5i20_0_encoder.00.position increments by 20 units
Not sure where to go from here ?
12 Mar 2016 03:19 #71476 by cmorley
Is this a step and direction drive or analog servo?
7i48...I guess analog servo.
Can you try the using linuxcnc rather then the test...servo test is fairly new.
And then please post your config files....could be a scaling problem.
Chris M
14 Mar 2016 08:49 #71611 by marsheng
I tried a second motor and servo and have the same issue.
I have attached the files.
I'm using MCG inc DMC 6D drives set to voltage mode.
See www.ebay.com/itm/MCG-DMC6D-BRUSH-TYPE-PW...DMC-6D-/330537737719
I have to get this going. I see from my profile that I joined 5 years ago and still don't have a machine up and running. Hmm.
15 Mar 2016 13:15 #71679 by andypugh
I am rather confused about your talk of "pulses" and "steps". 2 counts for 0.5V and 20 counts for 5V is at least consistent.
The HAL looks OK, but the PID gains and suchlike clearly need some tuning.
Also, if you are using FF1 then you probably want to connect the velocity feedback to the pid.N.feedback-deriv pins.
15 Mar 2016 19:35 #71695 by marsheng
Hi Andy
Thanks for the reply. The settings are the default from a new installation of 2.7.
I have not changed them (except X where P=1) . I assume that they would be at least a starting point.
The P=50 is quite strange as from experience P is normally around 1-5
Does anything in the setup explain why the + jog works and the - jog runs away ?
Thanks Wallace.
15 Mar 2016 20:22 #71696 by PCW
Wrong PWM mode for a 7I48 can behave this way
16 Mar 2016 02:26 #71706 by marsheng
Ok My mistake. When using PncConf it says the 7i48 daughter board requires UDM type generators and a PWM base frequency of 24 khz. I did not see the UDM requirement.
I now have the open loop test working, I can step + and - fine.
Trying the Tune Axis I get
PNCconf encountered an error. The following information may be useful in troubleshooting:
File "/usr/lib/pymodules/python2.7/pncconf/pages.py", line 1322, in on_update_tune_params
self.t.update_tune_test_params()
File "/usr/lib/pymodules/python2.7/pncconf/tests.py", line 858, in update_tune_test_params
' enc_scale':self.enc_scale,
KeyError: 'enc_scale'
16 Mar 2016 15:44 #71719 by andypugh
I don'r know how to solve the problem, but once you have the system behaving you can tune from inside the Axis GUI.
16 Mar 2016 20:22 #71745 by marsheng
One I have it operating is the question. I can tune from inside the program but at startup Acc, Velocity, following errors etc are the critical items to tune.
Is there a place to post the error so can be looked at?
Has anyone done a stand alone program that can adjust these parameters real time? It would be exceptionally useful addition. .
Thanks Wallace
16 Mar 2016 20:29 #71746 by PCW
You can adjust PID tuning parameters live via the calibrate menu in Axis
Time to create page: 0.101 seconds
