Velocity Won't Exceed 6000mm
20 Mar 2016 23:26 #71956
by THEQYD
Velocity Won't Exceed 6000mm was created by THEQYD
I'm trying to test my stepper drivers in PncConf, but the test window won't allow me to adjust the velocity beyond 6000mm/s.
I don't know what is happening. Please help.
21 Mar 2016 17:19 #71995
by Clive S
Replied by Clive S on topic Velocity Won't Exceed 6000mm
360m/min how fast do you want it to goI'm trying to test my stepper drivers in PncConf, but the test window won't allow me to adjust the velocity beyond 6000mm/s.
29 Mar 2016 14:57 - 29 Mar 2016 15:07 #72329
That is 21kph or 13mph. What are you building?
Replied by andypugh on topic Velocity Won't Exceed 6000mm
Last edit: 29 Mar 2016 15:07 by andypugh.
The following user(s) said Thank You: THEQYD
02 Apr 2016 20:52 #72582
by THEQYD
Replied by THEQYD on topic Velocity Won't Exceed 6000mm
Apologies, the measurements were minutes, not seconds.
02 Apr 2016 21:21 #72585
If you need higher speeds than the Wizards allow (though I am not sure why the wizards would enforce limits) then you can hand-editt he maximum velocities in the INI file:
linuxcnc.org/docs/2.7/html/config/ini-config.html
