changing max velocity
27 Mar 2016 10:12 #72204
by Ncmill.ts
changing max velocity was created by Ncmill.ts
hi im trying to change velocity in pncconfig but max is only 100mm\min is this a saftey feature ??because i want to run a lot faster and also do joggin much faster now when im tuning my servos.
how is this changed to a higher value?.
27 Mar 2016 19:30 #72223
Replied by cmorley on topic changing max velocity
What version of linuxcnc are you using?
It has probably been raised in later versions.
It's because I don't use metric - the limits make sense for imperial.
It can be changed in the INI file when your config is finished.
Chris M
Chris M
27 Mar 2016 20:15 #72225
by Ncmill.ts
Replied by Ncmill.ts on topic changing max velocity
Im using the latest version i think ,linuxcnc 2.7.4. And of course the imperial value is 25.4 times as high as the metric value.(25.4mm=1inch).
so i have to edit the ini file ,what should i look for?.and what program do i need to use to make an edit.
27 Mar 2016 20:59 - 27 Mar 2016 20:59 #72227
Replied by PCW on topic changing max velocity
The hal and ini files should be edited with a plain text editor
For a simple GUI text editor on wheezy, mousepad is one choice
on ubuntu dists, gedit is available (and you can add it to wheezy)
Last edit: 27 Mar 2016 20:59 by PCW.
Time to create page: 0.133 seconds
