5i25 with Probotix Unity Controller Problems
09 Apr 2016 19:47 #73008
by Irritant
5i25 with Probotix Unity Controller Problems was created by Irritant
I am getting no where using the config wizard. One key thing I don't understand is how the pin numbers are associated with the 5i25 card. I have never seen any way to do this. I know what the pin numbers should be, I had it all running with CNC doing the stepping but I had some latency issues so I bought the 5i25 card. I have read the books and to be honest this stuff is so far over my head that I don't even have to duck. Len at Probotix says this combo should work okay if the pins are set correctly. Can anyone help me get this running?
09 Apr 2016 20:34 #73010
Replied by PCW on topic 5i25 with Probotix Unity Controller Problems
What problems do you have?
( that is, what is working and what is not working? )
You can list the current 5I25 configurations pin and GPIO numbers with the mesaflash utility:
sudo mesaflash --device 5i25 --readhmid
09 Apr 2016 20:46 #73011
by Irritant
Replied by Irritant on topic 5i25 with Probotix Unity Controller Problems
what folder do I need to be in?
09 Apr 2016 23:42 #73016
it does not matter
10 Apr 2016 00:10 #73018
by Irritant
I guess it is not in my computer because it does not work. Where can I find it to install?
10 Apr 2016 00:19 #73020
If you have a recent standard LinuxCNC installation, you should just have to:
sudo apt-get install mesaflash
10 Apr 2016 00:24 - 10 Apr 2016 00:29 #73021
by Irritant
It worked
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 8 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
There are 2 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
14 1 IOPort PWM 0 PWM (Out)
2 2 IOPort StepGen 0 Step/Table1 (Out)
15 3 IOPort None
3 4 IOPort StepGen 0 Dir/Table2 (Out)
16 5 IOPort PWM 0 Dir (Out)
4 6 IOPort StepGen 1 Step/Table1 (Out)
17 7 IOPort None
5 8 IOPort StepGen 1 Dir/Table2 (Out)
6 9 IOPort StepGen 2 Step/Table1 (Out)
7 10 IOPort StepGen 2 Dir/Table2 (Out)
8 11 IOPort StepGen 3 Step/Table1 (Out)
9 12 IOPort StepGen 3 Dir/Table2 (Out)
10 13 IOPort None
11 14 IOPort QCount 0 Quad-A (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-IDX (In)
IO Connections for P2
1 17 IOPort None
14 18 IOPort PWM 1 PWM (Out)
2 19 IOPort StepGen 4 Step/Table1 (Out)
15 20 IOPort None
3 21 IOPort StepGen 4 Dir/Table2 (Out)
16 22 IOPort PWM 1 Dir (Out)
4 23 IOPort StepGen 5 Step/Table1 (Out)
17 24 IOPort None
5 25 IOPort StepGen 5 Dir/Table2 (Out)
6 26 IOPort StepGen 6 Step/Table1 (Out)
7 27 IOPort StepGen 6 Dir/Table2 (Out)
8 28 IOPort StepGen 7 Step/Table1 (Out)
9 29 IOPort StepGen 7 Dir/Table2 (Out)
10 30 IOPort None
11 31 IOPort QCount 1 Quad-A (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-IDX (In)
FPGA Size: 9 KGates
FPGA Pins: 144
IDROM Type: 3
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
Version: 0
Registers: 5
BaseAddress: 4100
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 0 IOPort None
15 3 IOPort None
17 7 IOPort None
10 13 IOPort None
1 17 IOPort None
15 20 IOPort None
17 24 IOPort None
10 30 IOPort None
Last edit: 10 Apr 2016 00:29 by Irritant.
10 Apr 2016 00:31 #73022
by Irritant
Since I have been fooling with this I have more than one config. How does it know which one it's reading? I copied this with it running the most correct config.
10 Apr 2016 00:42 #73023
When you launch LinuxCNC you should have the option to choose the config
( by the ini file name )
You can also launch LinuxCNC from the command line with the ini
file name as the argument, for example:
LinuxCNC ~/linuxcnc/configs/7i76es1.ini
10 Apr 2016 00:45 - 10 Apr 2016 00:50 #73024
by Irritant
Yes I have launched the most correct config this way.
Out of this the estop is the only thing that works correctly.
Last edit: 10 Apr 2016 00:50 by Irritant.
Time to create page: 0.161 seconds
