7i43 BITFILE issue for UART TX
14 Apr 2016 23:09 - 14 Apr 2016 23:11 #73327
by gandalf
7i43 BITFILE issue for UART TX was created by gandalf
I did lot of BITFILE compilation but now I have an issue trying to use UART TX.
I addedd in the .vhd bitfile Mudile ID section the line:
(UARTTTag, x"00", ClockLowTag, x"02", UARTTDataAddr&PadT, UARTTNumRegs, x"10", UARTTMPBitMask),
As Mudule ID structure definition in IDROMConst.vhd the stride is x"10"
type ModuleRecord is -- probably need an alternate way for smart modules
record
GTag : std_logic_vector(7 downto 0);
Version : std_logic_vector(7 downto 0);
Clock : std_logic_vector(7 downto 0);
NumInstances : std_logic_vector(7 downto 0);
BaseAddr : std_logic_vector(15 downto 0);
NumRegisters : std_logic_vector(7 downto 0);
Strides : std_logic_vector(7 downto 0);
MultRegs : std_logic_vector(31 downto 0);
end record;
type ModuleIDType is array(0 to MaxModules-1) of ModuleRecord;
Bitfile was compiled but when AXIS start I get the error:
hm2_7i43: loading HostMot2 Mesa 7i43 driver version 0.3
hm2/hm2_7i43.0: inconsistent Module Descriptor for UART Transmit Channel, not loading driver
hm2/hm2_7i43.0: Version = 0, expected 0
hm2/hm2_7i43.0: NumRegisters = 4, expected 4
hm2/hm2_7i43.0: InstanceStride = 0x00000040, expected 0x00000010
hm2/hm2_7i43.0: MultipleRegisters = 0x0000000F, expected 0x0000000F
hm2/hm2_7i43.0: inconsistent Module Descriptor!
hm2/hm2_7i43.0: failed to parse Module Descriptor 5
So it is reported strides is 0x40 and it expects 0x10 but strides is configured as 0x10 in vhd file.
I attach .BIT and .vhd, can someone try to load this bitfile for a 7i43 ?
Any idea? The source come from mesanet.com,
record
end record;
Last edit: 14 Apr 2016 23:11 by gandalf.
14 Apr 2016 23:15 #73328
by gandalf
Replied by gandalf on topic 7i43 BITFILE issue for UART TX
15 Apr 2016 01:45 - 15 Apr 2016 01:45 #73329
Replied by PCW on topic 7i43 BITFILE issue for UART TX
in the top level file, comment out the InstStride1: integer := 64; line and uncomment the InstStride1: integer := 16; line
InstStride1: integer := 64; -- instance stride 1 = 64 bytes = 16 x 32 bit registers sserial
-- InstStride1: integer := 16; -- 4..7 16 for BSPI/UART Ick double Ick
This does mean you cannot currently combine BSPI or UARTs with SSERIAL
(you can use the PktUART however)
I intend to fix this mess with the next IDROM version
Last edit: 15 Apr 2016 01:45 by PCW.
The following user(s) said Thank You: gandalf
15 Apr 2016 07:22 #73335
by gandalf
I will try PktUART.
Do hm2_uart_* API calls manage PktUART?
I am compiling source code from mesanet.com/software/parallel/7i43.zip, does it contain the latest source code version?
15 Apr 2016 18:28 #73356
I'm not sure about PktUART support. It uses a different driver and I dont know if it has been merged with LinuxCNC (it was written for Machinkit)
the 7I43.zip file should be the latest
15 Apr 2016 21:49 - 15 Apr 2016 21:50 #73373
by gandalf
I think I will wait for the next IDROM version. I have a 7i44 and I want to try to reserve few rj45 ports for SSERIAL and others for UART. It would be a very flexible communication solution.
Last edit: 15 Apr 2016 21:50 by gandalf.
27 Apr 2016 20:59 - 27 Apr 2016 21:20 #73966
by gandalf
I just compiled from the latest hostmot2-firmware.git snapshot tree (git.linuxcnc.org/gitweb?p=hostmot2-firmware.git;a=tree) and it worked well with ISE 13.4. With my surprise the makefile built also the xml file for Pncconf :).
It seems BIT file working.
Is Hostmot2 source (from git ) stable?
Last edit: 27 Apr 2016 21:20 by gandalf.
28 Apr 2016 09:47 #73994
Yes.
Replied by andypugh on topic 7i43 BITFILE issue for UART TX
Yes.
Time to create page: 0.146 seconds
